1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: caput works only the first time
From: "Tran, Phi Dung via Tech-talk" <[email protected]>
Date: Fri, 17 Nov 2023 20:20:24 +0000
After starting st.cmd, I caput $(P) 1 which is my soft channel and it successfully moved the other three real motors.
Subsequently, I repeat caput $(P) 2 or any other values less than 20 or greater than -20. By setting $(P).TPRO to 1, I can see that it was process  but it did not continue to field(OUT,"$(P)-AM PP MS") like the first input after launching st.cmd.
Please advice.
Thank you,
Phi
Attachment: galil0_pitch.db
Description: galil0_pitch.db
Re: caput works only the first time Tran, Phi Dung via Tech-talk
Prev: Re: synApps build Mark Rivers via Tech-talk
Next: Re: caput works only the first time Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
