1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: "duty cycle" records
From: Gerrit Kühn via Tech-talk <[email protected]>
Date: Wed, 22 Nov 2023 09:42:41 +0100
Hello,
I have a particle counter that I can talk to via StreamDevice. Its laser
diode has a limited lifetime, so I don't want to operate it continuously.
Instead, I'd like to send an "enable" command, have the device running for
a configurable time (like 5min), then send a "disable" command and wait
for a longer time (like 55min) until the next cycle is started.
Measured data could be sent by the device continuously and parsed via "I/O
Intr" scanning. But how would I trigger the needed enable/disable commands
with a given duty cycle (instead of simple scanning)? While searching, I
found references to Timer Records, Sequencing Records and other interesting
things, but (having zero experience with any of these so far) I am unsure
which would be the best choice here.
Are there any recommendations or even some simple examples (this is
probably a pretty common task)?
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: "duty cycle" records Ralph Lange via Tech-talk
Prev: Job opportunities at TIFR Sandeep Kumar Malu via Tech-talk
Next: Re: "duty cycle" records Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
