Hello! I previously used the EPICS Module to communicate with TwinCAT controllers over ADS protocol (https://github.com/EuropeanSpallationSource/epics-twincat-ads). The programme runs correctly. When I switched to another Beckhoff PLC, I then used BeckhoffADS module (https://github.com/EuropeanSpallationSource/epics-twincat-ads/BeckhoffADS)to test the connected PLC as follows: # Authorise my ADS client for the TwinCAT target by adding an AMS route. # Switching directories cd example/ # build make # and run the example make test The following error occurs: [newuser@localhost example]$ make test ./example.bin 2023-11-24T19:33:57+0800 Info: Connected to 192.168.3.10 Running step 1 2023-11-24T19:33:57+0800 Error: read frame failed with error: 104 2023-11-24T19:33:57+0800 Info:connection closed by remote Add device port: 0x851 Add device notification failed with: 1861 Running step 2 notificationByNameExample(): make: *** [test] Broken pipe What can I do to fix this?Thank you for your time.
ANJ, 28 Nov 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
