1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: C and C++ standard required by EPICS 7 Base and modules?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 28 Nov 2023 23:19:59 -0600
Hello!
What C language standard (e.g., C99) and C++ language standard
(e.g., C++11) does EPICS 7 Base require?
Also, is there a C and C++ language standard for EPICS 7 modules?
BTW, the EPICS 7 Base build system does not specify a C and C++ standard
when compiling (e.g., via a "-std=" compiler option) on most platforms,
but I think it should on all platforms.  I only see that compiler option
being used in the following:
  configure/os/CONFIG.Common.solaris-sparc-gnu
  configure/os/CONFIG.Common.solaris-x86-gnu
  configure/os/CONFIG.Common.RTEMS-uC5282
Without that option, the standard when compiling is just whatever the
compiler defaults to.
Thanks!
Lewis
Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
Prev: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) J. Lewis Muir via Tech-talk
Next: Re: Simulated limit switches on motorSim motor Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: IP230 driver Qing Ma via Tech-talk
Next: Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
