1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL)
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: Carsten Winkler <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Nov 2023 10:37:15 -0600
On 11/24, Michael Davidsaver via Tech-talk wrote:
> Both PVA and CA protocols depend on less common features of TCP/IP
> stacks which behave slightly differently on Linux vs. Windows vs. BSD.
> Over the years, we have identified a set of workarounds for these
> "quirks".  Of course this depend on being able to identify which TCP/IP
> stack implementation is actually *running*.  A build time check is
> not sufficient.
> With WSL 1, I was not able to find a reliable way to identify that
> this "Linux" host actually has Windows IP stack quirks.
> The opposite situation exists with WINE where a "Windows" host
> actually has Linux IP stack quirks.  Unlike WSL 1, this situation
> can be detected at runtime.
If a certain property can't be detected at run time but needs to be, how
about providing a way to set the property at run time since the user
will know what it should be set to?
Lewis
Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
Prev: Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Next: C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
Next: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
