1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Simulated limit switches on motorSim motor
From: "Nariyoshi, Pedro via Tech-talk" <[email protected]>
To: Torsten Bögershausen <[email protected]>, Kevin Peterson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Nov 2023 16:22:34 +0000
Hi Torsten,
I do have the most current motorsim motor. The simulated individual arm "motors" are using the motorsim module (DTYP=asynMotor), but I have the gap and center "motors" (with DTYP=Soft Channel using RDBL/DINP/etc) that are used to control the individual motors via a network of calc records.
The longer story is that our goal is to eventually plug this IOC into a real pair of slit arms. The arms are designed in a way that does not prevent collisions, so we are using the gap/center controls to prevent damage to the slit arms. I originally had the center/gap controls as simple ao records, but it was desired that if the motors stopped (via STOP field or limit switch) that the set points update (copying the readback to the setpoint, similar to what the SYNC field does). I had tried to use auxilary records to sync these up, but I often ended with a infinite loop of write to set point -> motor tries to move -> limit switch is hit -> update set-point -> motor tries to move -> etc. This is why I decided to try to use virtual motors.
Pedro Nariyoshi
Software Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7352
Email: [email protected]
1633986722804
Sent: Tuesday, November 28, 2023 10:41:14 AM
To: Nariyoshi, Pedro; Kevin Peterson; [email protected]
[EXTERNAL] This email originated from outside of FRIB
Hej Pedro,
That depends. There may be an easy way to do what you want –
on the driver level.
Are you using a model 3 driver ?
/Torsten
From: Tech-talk <[email protected]> on behalf of "Nariyoshi, Pedro via Tech-talk" <[email protected]>
Reply to: "Nariyoshi, Pedro" <[email protected]>
Date: Tuesday, 28 November 2023 at 16:36
To: Kevin Peterson <[email protected]>, "[email protected]" <[email protected]>
Hi Kevin,
I figured I could try to remove the SPC_NOMOD from the dbd (and a bo/calcout record to write to it), but it feels too hackish. What I was really trying to figure out is if there was a field I could put a link in to set the limit switch fields (similar to RDBL/DINP/etc).
Sent: Tuesday, November 28, 2023 10:18:13 AM
To: Nariyoshi, Pedro; [email protected]
Pedro,
The HLS/LLS/RHLS/RLLS fields are read-only.
Kevin
On 11/21/23 12:24, Nariyoshi, Pedro via Tech-talk wrote:
> Hi,
> I am working on creating virtual motors to control some slits. One
> problem I have is that I couldn't find a way to set the
> HLS/LLS/RHLS/RLLS fields. Is there a way to control these (whether
> having an input link to these values or a writing them directly with a
> calcout or bo record)?
> Thank you very much
> *Pedro Nariyoshi*
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
JPEG image
Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Re: Simulated limit switches on motorSim motor Kevin Peterson via Tech-talk
Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Re: Simulated limit switches on motorSim motor Torsten Bögershausen via Tech-talk
Prev: Re: Simulated limit switches on motorSim motor Kevin Peterson via Tech-talk
Next: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Simulated limit switches on motorSim motor Torsten Bögershausen via Tech-talk
Next: Re: Simulated limit switches on motorSim motor Kevin Peterson via Tech-talk
