1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Simulated limit switches on motorSim motor
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: "Nariyoshi, Pedro" <[email protected]>, Kevin Peterson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Nov 2023 15:41:14 +0000
Hej Pedro,
That depends. There may be an easy way to do what you want –
on the driver level.
Are you using a model 3 driver ?
/Torsten
From: Tech-talk <[email protected]> on behalf of "Nariyoshi, Pedro via Tech-talk" <[email protected]>
Reply to: "Nariyoshi, Pedro" <[email protected]>
Date: Tuesday, 28 November 2023 at 16:36
To: Kevin Peterson <[email protected]>, "[email protected]" <[email protected]>
Hi Kevin,
I figured I could try to remove the SPC_NOMOD from the dbd (and a bo/calcout record to write to it), but it feels too hackish. What I was really trying to figure out is if there was a field I could put a link in to set the limit switch fields (similar to RDBL/DINP/etc).
Sent: Tuesday, November 28, 2023 10:18:13 AM
To: Nariyoshi, Pedro; [email protected]
[EXTERNAL] This email originated from outside of FRIB
Pedro,
The HLS/LLS/RHLS/RLLS fields are read-only.
Kevin
On 11/21/23 12:24, Nariyoshi, Pedro via Tech-talk wrote:
> Hi,
> I am working on creating virtual motors to control some slits. One
> problem I have is that I couldn't find a way to set the
> HLS/LLS/RHLS/RLLS fields. Is there a way to control these (whether
> having an input link to these values or a writing them directly with a
> calcout or bo record)?
> Thank you very much
> *Pedro Nariyoshi*
Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Re: Simulated limit switches on motorSim motor Kevin Peterson via Tech-talk
Prev: Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Next: Re: "duty cycle" records Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
