1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL)
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Cc: Carsten Winkler <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Nov 2023 10:19:33 -0800
On 11/28/23 08:37, J. Lewis Muir wrote:
On 11/24, Michael Davidsaver via Tech-talk wrote:
Both PVA and CA protocols depend on less common features of TCP/IP
stacks which behave slightly differently on Linux vs. Windows vs. BSD.
Over the years, we have identified a set of workarounds for these
"quirks".  Of course this depend on being able to identify which TCP/IP
stack implementation is actually *running*.  A build time check is
not sufficient.
With WSL 1, I was not able to find a reliable way to identify that
this "Linux" host actually has Windows IP stack quirks.
The opposite situation exists with WINE where a "Windows" host
actually has Linux IP stack quirks.  Unlike WSL 1, this situation
can be detected at runtime.
If a certain property can't be detected at run time but needs to be, how
about providing a way to set the property at run time since the user
will know what it should be set to?
Personally, I don't think WSL1 is worth my effort at this point.
However, as I have said.  EPICS is what contributors make it.
Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) J. Lewis Muir via Tech-talk
Prev: Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
Next: Re: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) J. Lewis Muir via Tech-talk
Next: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
