1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: C and C++ standard required by EPICS 7 Base and modules?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 29 Nov 2023 10:17:35 -0800
On 11/29/23 09:55, J. Lewis Muir wrote:
On 11/29, Michael Davidsaver wrote:
On 11/28/23 21:19, J. Lewis Muir via Tech-talk wrote:
What C language standard (e.g., C99) and C++ language standard
(e.g., C++11) does EPICS 7 Base require?
Currently epics-base and the bundled PVA modules should build with -std=c++98.
Thanks!  And what about C?
In practice, my answer is the same.  The toolchains we test with.
eg. RTEMS 4.9 has GCC 4.4.
On "paper" C89.  I am less certain that Base would actually build with
-std=c89 as we may use some compiler specific features in OS/compiler
specific code.
Also, is there a C and C++ language standard for EPICS 7 modules?
BTW, the EPICS 7 Base build system does not specify a C and C++ standard
when compiling (e.g., via a "-std=" compiler option) on most platforms,
but I think it should on all platforms.  I only see that compiler option
being used in the following:
Of more practical importance than -std=... we test with older G++ and MSVC.
eg. with my PVXS modules, while I say >= c++11.  In practice my compatibility
target is g++ >= 4.8 (circa RHEL7) which implemented most, but not all, of c++11.
Thanks!  And again, what about C?
PVXS is written in C++.
Re: C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
Prev: RE: Simulated limit switches on motorSim motor Mark Rivers via Tech-talk
Next: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
Next: Re: C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
