1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: C and C++ standard required by EPICS 7 Base and modules?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 29 Nov 2023 11:55:30 -0600
On 11/29, Michael Davidsaver wrote:
> On 11/28/23 21:19, J. Lewis Muir via Tech-talk wrote:
> > What C language standard (e.g., C99) and C++ language standard
> > (e.g., C++11) does EPICS 7 Base require?
> Currently epics-base and the bundled PVA modules should build with -std=c++98.
Thanks!  And what about C?
> > Also, is there a C and C++ language standard for EPICS 7 modules?
> > BTW, the EPICS 7 Base build system does not specify a C and C++ standard
> > when compiling (e.g., via a "-std=" compiler option) on most platforms,
> > but I think it should on all platforms.  I only see that compiler option
> > being used in the following:
> Of more practical importance than -std=... we test with older G++ and MSVC.
> eg. with my PVXS modules, while I say >= c++11.  In practice my compatibility
> target is g++ >= 4.8 (circa RHEL7) which implemented most, but not all, of c++11.
Thanks!  And again, what about C?
Lewis
Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
Prev: RE: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Mark Rivers via Tech-talk
Next: RE: Simulated limit switches on motorSim motor Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
Next: Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
