1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Problem deploying Archiver Appliance
From: Eusebio Naif Al-Soliman Fuentes via Tech-talk <tech-talk at aps.anl.gov>
To: Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 29 Nov 2023 16:46:53 +0100
Hello everybody.
I'm deploying a basic Archiver Appliance in a Virtual Machine with the install_scripts/single_machine_install.sh script. I have encountered the next error in the retrieval/logs/catalina.err file:
Nov 29, 2023 4:00:30 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Error configuring application listener of class [org.epics.archiverappliance.config.ArchServletContextListener]
java.lang.NoClassDefFoundError: javax/servlet/ServletContextListener
    at java.base/java.lang.ClassLoader.defineClass1(Native Method)
    at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1012)
    at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150)
    at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2352)
    at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:800)
    at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1317)
    at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1165)
    at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:491)
    at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:473)
    at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:143)
    at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4349)
    at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4860)
    at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171)
    at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683)
    at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658)
    at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:712)
    at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:975)
    at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1952)
    at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
    at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
    at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
    at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123)
    at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:776)
    at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:426)
    at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1659)
    at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
    at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:114)
    at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:402)
    at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:345)
    at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:893)
    at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:845)
    at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1332)
    at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1322)
    at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145)
    at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:866)
    at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:240)
    at org.apache.catalina.core.StandardService.startInternal(StandardService.java:433)
    at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:917)
    at org.apache.catalina.startup.Catalina.start(Catalina.java:795)
    at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
    at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.base/java.lang.reflect.Method.invoke(Method.java:568)
    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:347)
    at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:235)
Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContextListener
    at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1353)
    ... 55 more
Has someone encountered this problem? It also happens when I use the quickstart.sh script. I have tried with a CentOS 7 and Debian 10 VMs and in both I have the same issue.
There is another minor problem in the log:
Nov 29, 2023 4:00:21 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/home/usuario/archappl_install/retrieval/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/etl/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/engine/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/mgmt/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/EPICS/epics-base/lib/linux-x86_64:/home/usuario/archappl_install/apache-tomcat-10.1.16/lib:/usr/lib/jvm/jdk-17-oracle-x64/lib/server:/usr/lib/jvm/jdk-17-oracle-x64/lib:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib]
However, I don't think that this is the problem which it's blocking me, but it's still interesting to know what's happening with the SSL library, because I think that the dependencies are already installed.
Thanks in advance. Eusebio.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
eunaif at correo.ugr.es
Re: [EXTERNAL] Problem deploying Archiver Appliance Kasemir, Kay via Tech-talk
Prev: Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
Next: Re: [EXTERNAL] Problem deploying Archiver Appliance Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Wlodek, Jakub via Tech-talk
ANJ, 29 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
