1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: [EXTERNAL] Problem deploying Archiver Appliance
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Eusebio Naif Al-Soliman Fuentes <[email protected]>, Tech Talk <[email protected]>
Date: Wed, 29 Nov 2023 15:52:28 +0000
> :/home/usuario/archappl_install/apache-tomcat-10.1.16/lib …
> java.lang.NoClassDefFoundError: javax/servlet/ServletContextListener
Looks like you’re using Tomcat 10, which changed the API.
Classes javax/servlet have been renamed/moved to Jakarta/servlet.
Try using tomcat 9 which still has the javax/servlet classes
From: Tech-talk <[email protected]> on behalf of Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]>
Date: Wednesday, November 29, 2023 at 10:47 AM
To: Tech Talk <[email protected]>
Subject: [EXTERNAL] Problem deploying Archiver Appliance
Hello everybody.
I'm deploying a basic Archiver Appliance in a Virtual Machine with the install_scripts/single_machine_install.sh script. I have encountered the next error in the retrieval/logs/catalina.err file:
Nov 29, 2023 4:00:30 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Error configuring application listener of class [org.epics.archiverappliance.config.ArchServletContextListener]
    at java.base/java.lang.ClassLoader.defineClass1(Native Method)
    at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1012)
    at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150)
    at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2352)
    at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:800)
    at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1317)
    at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1165)
    at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:491)
    at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:473)
    at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:143)
    at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4349)
    at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4860)
    at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171)
    at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683)
    at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658)
    at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:712)
    at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:975)
    at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1952)
    at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
    at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
    at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
    at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123)
    at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:776)
    at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:426)
    at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1659)
    at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
    at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:114)
    at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:402)
    at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:345)
    at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:893)
    at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:845)
    at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1332)
    at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1322)
    at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145)
    at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:866)
    at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:240)
    at org.apache.catalina.core.StandardService.startInternal(StandardService.java:433)
    at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:917)
    at org.apache.catalina.startup.Catalina.start(Catalina.java:795)
    at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
    at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.base/java.lang.reflect.Method.invoke(Method.java:568)
    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:347)
    at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:235)
Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContextListener
    at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1353)
    ... 55 more
Has someone encountered this problem? It also happens when I use the quickstart.sh script. I have tried with a CentOS 7 and Debian 10 VMs and in both I have the same issue.
There is another minor problem in the log:
Nov 29, 2023 4:00:21 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/home/usuario/archappl_install/retrieval/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/etl/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/engine/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/mgmt/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/EPICS/epics-base/lib/linux-x86_64:/home/usuario/archappl_install/apache-tomcat-10.1.16/lib:/usr/lib/jvm/jdk-17-oracle-x64/lib/server:/usr/lib/jvm/jdk-17-oracle-x64/lib:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib]
However, I don't think that this is the problem which it's blocking me, but it's still interesting to know what's happening with the SSL library, because I think that the dependencies are already installed.
Thanks in advance. Eusebio.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
Re: [EXTERNAL] Problem deploying Archiver Appliance Eusebio Naif Al-Soliman Fuentes via Tech-talk
Prev: Problem deploying Archiver Appliance Eusebio Naif Al-Soliman Fuentes via Tech-talk
Next: Re: [EXTERNAL] Problem deploying Archiver Appliance Eusebio Naif Al-Soliman Fuentes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
