I am not 100% sure if my answer applies to the the I/O Intr scan, but: When you caput to a record (I am assuming you put to the VAL
field, for other fields you need to consult the record reference
documentation), this causes the record to *process*. The input
link(s) will be processed and the VAL field will be updated (i.e.
the value you just put with caput will be clobbered). If the VAL
field changes by more than the monitor delta, the record will
issue a monitor, otherwise not. HTH - rolf - On 2023-12-05 8:12 a.m., Gerrit Kühn
via Tech-talk wrote:
Am Tue, 5 Dec 2023 15:26:16 +0000 schrieb Érico Nogueira Rolim <[email protected]>:From [1]: Passive records are processed when they are referenced by other records through their link fields or when a channel access put is done to them.Um, yes, but the record in question isn't passive, it's I/O Intr. It does not say "*Only* passive records are processed...".A record must be Passive in order to be *processed* (therefore sending an event to your camonitor process) when it receives a value write.I do not understand this from what you quoted. The quote is only on passive records and says nothing about I/O Intr. Further below it even says on processing --- For output links, this option allows a request for remote processing (side-effects). none (default) - Make no special request. Uses a server specific default. false, “NPP” - Request to skip processing. true, “PP” - Request to force processing. “CP”, “CPP” - For output links, an alias for “PP”. --- I even tried that (writing values from a calcout record to the I/O Intr record using PP), but camonitor did not take notice on that case, either.I believe a possible workaround would be an auxiliary record(s), first writing the value and then writing to "$record.PROC CA". I know that works to force processing for records with periodic scanning, but don't remember testing with I/O Intr.Would that be considered a better/cleaner solution than what I already came up with (using an auxilary record for I/O Intr and having the actual data record passive)? cu Gerrit --
Rolf Keitel, Ph.D. Researcher Emeritus e-mail: [email protected] ------ Home ------ 4158 West 13th Ave Vancouver, BC, V6R 2T6 604 228 0594 ------ Office: ------ 604 222 7453 TRIUMF Canada’s particle accelerator centre 4004 Wesbrook Mall Vancouver, BC, V6T 2A3 www.triumf.ca | Twitter | Facebook | Instagram TRIUMF is located on the traditional, ancestral, and unceded territory of the xʷməθkʷəy̓əm (Musqueam) people, who for millennia have passed on their culture, history, and traditions from one generation to the next on this site.
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
