Or this link:
https://github.com/NSLS-II/windows-epics-config
Historically and ironically, it seems more troublesome to build EPICS stuff on Windows than on Linux. I saw similar errors quite a while ago.
My colleague, Jakub Wlodek, developed scripts to automate the builds of EPICS base, areaDetector, and other support modules on Windows. Try this:
https://github.com/huyong1979/windows-epics-config
Cheers,
Yong
Does your ioc CONFIG_SITE include $(AREA_DETECTOR)/configure/CONFIG_SITE ?
Freddie
On Behalf Of Freddie Akeroyd - STFC UKRI via Tech-talk
Sent: 06 December 2023 12:35
To: [email protected]
Subject: RE: Windows 10 LNK1181 error on xml2.lib
- the “link” command even points to ADSupport/lib/linux-x86_64
I assume you mean
ADSupport/lib/windows-x64 ? And Xml2.lib exists in this location?
Freddie
On Behalf Of Ralph Lange via Tech-talk
Sent: 06 December 2023 08:59
To: EPICS Tech Talk <[email protected]>
Subject: Re: Windows 10 LNK1181 error on xml2.lib
[...], the “link” command even points to ADSupport/lib/linux-x86_64, and the windows PATH variable points to the same location but still
I get the same LNK1181 issue.
Keep in mind that Windows DLLs are in the "bin" install location, while statically linked libraries and the DLL stub libraries are under "lib". Under Windows, PATH needs to point to the DLLs,
i.e. should contain the "bin" location.
- Re: Windows 10 LNK1181 error on xml2.lib Ralph Lange via Tech-talk
- Windows 10 LNK1181 error on xml2.lib Abdalla Ahmad via Tech-talk
- RE: Windows 10 LNK1181 error on xml2.lib Freddie Akeroyd - STFC UKRI via Tech-talk
- Re: Windows 10 LNK1181 error on xml2.lib Hu, Yong via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
