1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: CaSnooper Update?
From: "Murray, Doug via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 7 Dec 2023 14:46:58 +0000
Excellent, I’m looking at Ken’s original source now and will check the java version as well.
cheers
-doug
Date: Wednesday, December 6, 2023 at 9:55
 AM
To: Johnson, Andrew N. <[email protected]>, Murray, Doug <[email protected]>, [email protected] <[email protected]>
> However I suspect it might be easier to start from scratch (I'd recommend using the PVXS API) to implement a separate pvSnooper program.
I agree.
For what it’s worth, the core-pva java library already contains a PVA search monitor that does a lot of what caSnooper does for Channel Access.
It’s not much code, see https://github.com/ControlSystemStudio/phoebus/blob/master/core/pva/src/main/java/org/epics/pva/server/PVASearchMonitorMain.java
Example Usage:
$ ./pvasearchmonitor -h
USAGE: pvasearchmonitor [options]
Options:
  -h             Help
  -p <seconds>   Update period (default 10 seconds)
  -1             Update once, then quit
  -v <level>     Verbosity, level 0-5
Waits for the specified period,
then prints information about received search requests.
Output of running it while calling “pvget Demo Test AnotherPV” in another window:
$ ./pvasearchmonitor -p 10 -1
Monitoring search requests for 10 seconds...
Count Name                 Last Client                                Age
   36 Demo                 /10.1.58.230:50842                       2 sec
   36 Test                 /10.1.58.230:50842                       2 sec
   36 AnotherPV            /10.1.58.230:50842                       2 sec
Done.
For a C++ implementation I agree that PVXS would be a good starting point.
Kay
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Date: Wednesday, December 6, 2023 at 12:27 PM
To: Murray, Doug <[email protected]>, [email protected] <[email protected]>
Subject: [EXTERNAL] Re: CaSnooper Update?
HI Doug,
caSnooper was written by Ken Evans, and hasn't been maintained since 2013, before Janet Anderson retired. If SLAC wants to maintain it you're welcome to take it over, I'd be happy to provide a git repo containing the CVS commit history.
- Andrew
Complexity comes for free, Simplicity you have to work for.
From: Tech-talk <[email protected]> on behalf of Murray, Doug via Tech-talk <[email protected]>
Date: Wednesday, December 6, 2023 at 8:49 AM
To: [email protected] <[email protected]>
Subject: CaSnooper Update?
The caSnooper tool is still being used at SLAC, is it being used elsewhere and is there interest in having it updated to support pvAccess?
cheers
-doug
CaSnooper Update? Murray, Doug via Tech-talk
Re: CaSnooper Update? Johnson, Andrew N. via Tech-talk
Re: CaSnooper Update? Kasemir, Kay via Tech-talk
Prev: Pezca documentation, installation Rong Huang via Tech-talk
Next: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget Copping, Oliver (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: CaSnooper Update? Kasemir, Kay via Tech-talk
Next: Pezca documentation, installation Rong Huang via Tech-talk
