1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>, "Copping, Oliver (DLSLtd, RAL, LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 7 Dec 2023 18:35:01 +0000
Hi Oliver,
If you merely want those records to not be in alarm state when the IOC starts without having to process them you can set their SEVR fields to 0 in the .db file(s). Using autosave to record and restore their values after reboot might also be worth trying, but I'm not sure if that will clear the initial alarm state, you might still have to clear SEVR.
- Andrew
Complexity comes for free, Simplicity you have to work for.
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Date: Thursday, December 7, 2023 at 11:53 AM
To: Copping, Oliver (DLSLtd, RAL, LSCI) <[email protected]>, [email protected] <[email protected]>
Subject: RE: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget
Hi Oliver,
I think this is similar to the issue discussed recently in this tech-talk thread: https://epics.anl.gov/tech-talk/2023/msg01867.php
  • The records stay INVALID even if the user attempts to change the values in the input fields.
The record status is INVALID because it has not processed yet.
Your records have SCAN=EVENT.  Because SCAN is not PASSIVE then when the user changes the VAL field the record will not process, and hence the status remains INVALID.
  • However, the values still do not update when a new one is entered until APPLY is pressed.
The record only sends monitor events for the VAL field when the record processes.  Because the record does not process when the user changes the VAL field, it does not send monitors, and hence the OPI screen does not update.
From: Tech-talk <[email protected]> On Behalf Of Copping, Oliver (DLSLtd, RAL, LSCI) via Tech-talk
Sent: Thursday, December 7, 2023 9:48 AM
To: [email protected]
Subject: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget
Hi Tech Talkers,
I have a Menu button widget linked to an MBBO record, that in turn triggers Event records corresponding to whichever option is selected and the APPLYed.
These options are specific motor position configurations for different experiments.
I have a series of AO records that take these position values for various motor positions, each with the SCAN fields set to EVENT.
When their corresponding EVENT is triggered, these AO records are processed, writing their VAL field to the motor demand position.
However, until the APPLY button is pressed, causing the EVENT to trigger, all the records are shown as INVALID.
The values do change in record VAL fields, just not on the screen.
Once the APPLY button is pressed, the records no longer show as INVALID, and show the new values.
Is there a way of making it so the records can be processed, showing the new VALs, without triggering the Events and writing to the motors?
I know I could just separate out the writing to motors to separate records, but then I would be doubling the number of records which isn't ideal.
This is using EPICS R3.14.12.7.
Some examples of the records associated with this:
<records.ao DOL="<PV>:CONFIG" DTYP="Soft Channel" FLNK="<PV>:CONFIG:APPLY:30UM:CALC" OMSL="closed_loop" SCAN="Passive" record="<PV>:CONFIG:APPLY"/>
<records.event EVNT="1" record="<PV>:CONFIG:30UM:APPLY"/>
<records.ao EVNT="1" OUT="<MOTOR_PV>:Y PP" SCAN="Event" VAL="38.6839" record="<PV>:CONFIG:30UM:MAPTY"/>
<records.calcout CALC="A = 0 ? 1 : 0" INPA="<PV>:CONFIG:APPLY" OEVT="1" OOPT="When Non-zero" record="<PV>:CONFIG:APPLY:30UM:CALC"/>
Ollie Copping
Software Systems Engineer
Diamond Light Source
OX11 0DE
Tel: 01235 395375
EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget Copping, Oliver (DLSLtd, RAL, LSCI) via Tech-talk
RE: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget Mark Rivers via Tech-talk
Prev: RE: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget Mark Rivers via Tech-talk
Next: Re: Pezca documentation, installation Rong Huang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Fwd: Raising alarms with P4P Claus, Ric via Tech-talk
