1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Pezca documentation, installation
From: Rong Huang via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Thu, 7 Dec 2023 22:23:00 -0600
Find a copy of pezca_1.1 source code that works with ezca_20070625
after minor modifications for linux-arm.
Not sure if anyone has a newer version of pezca (or a patch) that can
work with newer versions of ezca.
Rong
On Wed, Dec 6, 2023 at 9:37 PM Rong Huang <ronghuang at ls-cat.org> wrote:
> Dear tech-talkers,
> I am trying to install beamline IOCs and other software in a
> simulation PC with hardware links removed in EPICS module database.
> Hope this will still provide some degree of testing of non-EPICS
> scripts.
> New to the beamline and its software, I try to keep all software in
> original states, including the perl scripts and its use of Pezca.
> The new PC is a RHEL virtual machine in VMware, on a host of Apple M2 Mac.
> EPICS base version: 3.14.12.
> ezca was installed inside epics/extensions/src/ezca directory,
> generated extensions/lib/linux-arm/libezca.a (but not sure how it is
> used by Pezca).
> But I could not find any documentation over the internet about Pezca
> installation.
> Tried to create a symbolic link of an old "Pezca.pm" file to
> "/usr/lib64/perl5/vendor_perl/Pezca.pm", but it does not work. The
> error message of running a perl script is:
> Can't locate loadable object for module Pezca in @INC (@INC contains:
> /usr/lib64/perl5/vendor_perl /usr/local/lib64/perl5/5.32
> /usr/local/share/perl5/5.32 /usr/lib64/perl5/vendor_perl
> /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5) at
> /pf/epics/lscat/pezca/attenuationServer.pl line 14.
> Compilation failed in require at
> The line 14 of "attenuationServer.pl" is:
>        use Pezca;
> Sharing of Pezca documentation or any suggestions will be appreciated.
> Thanks,
> Rong
Pezca documentation, installation Rong Huang via Tech-talk
Prev: Re: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget Johnson, Andrew N. via Tech-talk
Next: Re: Simulated limit switches on motorSim motor Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Pezca documentation, installation Rong Huang via Tech-talk
Next: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget Copping, Oliver (DLSLtd, RAL, LSCI) via Tech-talk
ANJ, 08 Dec 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
