From the context menu, you can copy the PV name and then use that to run “cainfo” from the command line.
Note that you might then get the address of a CA gateway, not the IOC behind it.
When hovering the mouse over a display's widget the $(pv_name) and $(pv_value) are often shown. Is there a property that can show which IOC is serving that PV?
- Can phoebus tool tip show a PV's server? Paul Sichta via Tech-talk
Re: Can phoebus tool tip show a PV's server? Tynan Ford via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
