1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Can phoebus tool tip show a PV's server?
To: Paul Sichta <[email protected]>
Date: Mon, 11 Dec 2023 10:36:46 -0800
If your site uses Recsync and Channel Finder you can also use the right click Context Menu and select "Channel Info". This will show you the IOC name, host name, and IOC IP address and port.
On Mon, Dec 11, 2023 at 9:40 AM Paul Sichta via Tech-talk <[email protected]> wrote:
When hovering the mouse over a display's widget the $(pv_name) and $(pv_value) are often shown.  Is there a property that can show which IOC is serving that PV?
-ps
Can phoebus tool tip show a PV's server? Paul Sichta via Tech-talk
Prev: Re: [EXTERNAL] Can phoebus tool tip show a PV's server? Kasemir, Kay via Tech-talk
Next: Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: dbGetLink documentation update suggestion Ivo Hanak via Tech-talk
