1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: is there an EPICS module to makePvToArchiveFromDbInfo() ?
To: "Pearson, Matthew" <[email protected]>
Cc: "[email protected]" <[email protected]>, NADOT Victor <[email protected]>
Date: Thu, 14 Dec 2023 09:10:11 -0800
Hi Victor,
In case you are using the archiver appliance and channel finder/recsync, you can accomplish this via the channel finder AA processor - https://github.com/ChannelFinder/ChannelFinderService/blob/master/src/main/resources/application.properties#L96
Best,
Tynan
On Thu, Dec 14, 2023 at 7:24 AM Pearson, Matthew via Tech-talk <[email protected]> wrote:
Hi Victor,
If you use a recent version of base, you can list tags on the IOC shell and write them to a file:
epics> dbli *archive*
ST99:Det:IOC_SADet3:Status info(archive, "Monitor, 00:00:01, VAL")
ST99:Det:IOC_SADet3:StatCtrl info(archive, "Monitor, 00:00:01, VAL")
ST99:Det:IOC_SIDet3:STATUS info(archive, "Monitor, 00:00:01, VAL")
ST99:Det:IOC_SIDet3:STATCTRL info(archive, "Monitor, 00:00:01, VAL")
epics>
epics> dbli *archive* > /tmp/archive_list.txt
cat /tmp/archive_list.txt
Then you can parse that list and generate an archive configuration. Or, modify an archiver to be able to read that format.
We use a Python script to parse the database files, but if we were starting today I'd probably use the above method as the first step in extracting the info tags.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Simon Rose via Tech-talk
Sent: Thursday, December 14, 2023 5:23 AM
To: NADOT Victor <[email protected]>; [email protected]
Subject: [EXTERNAL] Re: is there an EPICS module to makePvToArchiveFromDbInfo() ?
Hi Victor -
There is one that we have used at ESS that might serve your purpose:
https://urldefense.us/v2/url?u=https-3A__gitlab.esss.lu.se_icshwi_iocmetadata&d=DwIGaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=aEDRFW1J1RKf3L4Vy5iLgaY2FJpZ2TV1XDtc_tKxW00&m=vNISIrtmTSvaQHTNeWDl1p15L43in4-yA1-44ChtrvumzGayCjG4ekJITH08uJbN&s=CH3zpoO636P0uNZGzJnegnwLIRfFkNbkML82l2Cap0E&e=
Note that it uses EPICS 7 NT types. There is pretty good documentation in the README file in the repository.
Cheers,
Simon
On 2023-12-14, 10:29, "Tech-talk on behalf of NADOT Victor via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hi all,
is there an EPICS module to, in the same way as `makeAutosaveFileFromDbInfo()` works, generate (at IOC boot, so macro are resolved) a file with a list of PV names to archive from the information provided in the record `info()` field ?
```epics
record(ai, "MyPv") {
info(archive, "YES")
This would be a nice tool to then copy/past all the pv list files to archive in the archiver.
Thanks for the answer,
Cheers,
Victor Nadot
Ingénieur Systèmes Electroniques Embarqués CEA Saclay - DRF / IRFU / DIS / LDISC Bâtiment 472 - pièce 120
+ 33 (0)1 69 08 41 88
+ 33 (0)6 45 03 12 54
Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? NADOT Victor via Tech-talk
Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? Simon Rose via Tech-talk
RE: is there an EPICS module to makePvToArchiveFromDbInfo() ? Pearson, Matthew via Tech-talk
Prev: RE: is there an EPICS module to makePvToArchiveFromDbInfo() ? Pearson, Matthew via Tech-talk
Next: Re: PVXS release 1.3.0 Murray, Doug via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? NADOT Victor via Tech-talk
