Hello,
Sorry I am living in the past. I am trying to install the old version
quadEM-R7-0 to match the EPICS_base version (3.14.12.8) and Asyn
version in use.
I installed everything without vxWorks, with the intention to run the
IOC on a PC. Currently working on RHEL linux-arm inside VMware Fusion.
The TetrAMM instrument is new, but I guess the error message is not
about hardware but EPICS software. The printout of starting IOC is as
follows:
[rh@localhost iocTetrAMM]$ ../../bin/linux-arm/quadEMTestApp st.cmd
errlogInit(5000)
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocTetrAMM")
epicsEnvSet("TOP","/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0")
epicsEnvSet("SUPPORT","/epicsioc/used/epics/synApps_5_8_3_14_8")
epicsEnvSet("AREA_DETECTOR","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5")
epicsEnvSet("EPICS_BASE","/epicsioc/used/epics/base-3.14.12.8")
epicsEnvSet("ASYN","/epicsioc/used/epics/synApps_5_8_3_14_8/asyn-4-36")
epicsEnvSet("ADSUPPORT","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADSupport")
epicsEnvSet("ADCORE","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADCore")
epicsEnvSet("AUTOSAVE","/epicsioc/used/epics/synApps_5_8_3_14_8/autosave-5-10")
epicsEnvSet("BUSY","/epicsioc/used/epics/synApps_5_8_3_14_8/busy-1-7-2")
epicsEnvSet("CALC","/epicsioc/used/epics/synApps_5_8_3_14_8/calc-3-7-3")
epicsEnvSet("SNCSEQ","/epicsioc/used/epics/synApps_5_8_3_14_8/seq-2-2-7")
epicsEnvSet("SSCAN","/epicsioc/used/epics/synApps_5_8_3_14_8/sscan-2-11-3")
epicsEnvSet("DEVIOCSTATS","/epicsioc/used/epics/synApps_5_8_3_14_8/iocStats-3-1-16")
epicsEnvSet("IPAC","/epicsioc/used/epics/synApps_5_8_3_14_8/ipac-2-15")
epicsEnvSet("IPUNIDIG","/epicsioc/used/epics/synApps_5_8_3_14_8/ipUnidig-2-10")
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in this build
epicsEnvSet("QUADEM","/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0")
dbLoadDatabase("/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/dbd/quadEMTestApp.dbd")
quadEMTestApp_registerRecordDeviceDriver(pdbbase)
# The search path for database files
# Note: the separator between the path entries needs to be changed to
a semicolon (;) on Windows
epicsEnvSet("EPICS_DB_INCLUDE_PATH",
"/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADCore/db:/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/db")
< /epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/iocBoot/iocTetrAMM/TetrAMM.cmd
epicsEnvSet("PREFIX", "quadEMTest:")
epicsEnvSet("RECORD", "TetrAMM:")
epicsEnvSet("PORT", "TetrAMM")
epicsEnvSet("TEMPLATE", "TetrAMM")
epicsEnvSet("QSIZE", "20")
epicsEnvSet("RING_SIZE", "10000")
epicsEnvSet("TSPOINTS", "2048")
#epicsEnvSet("IP", "164.54.160.165:10001")
epicsEnvSet("IP", "10.1.17.35:10001")
#drvAsynIPPortConfigure("portName","hostInfo",priority,noAutoConnect,
# noProcessEos)
drvAsynIPPortConfigure("IP_TetrAMM", "10.1.17.35:10001", 0, 0, 0)
asynOctetSetInputEos("IP_TetrAMM", 0, "\r\n")
asynOctetSetOutputEos("IP_TetrAMM", 0, "\r")
# Set both TRACE_IO_ESCAPE (for ASCII command/response) and
TRACE_IO_HEX (for binary data)
asynSetTraceIOMask("IP_TetrAMM", 0, 6)
#asynSetTraceFile("IP_$(PORT)", 0, "AHxxx.out")
#asynSetTraceMask("IP_$(PORT)", 0, 9)
asynSetTraceIOTruncateSize("IP_TetrAMM", 0, 4000)
# Load asynRecord record
dbLoadRecords("/epicsioc/used/epics/synApps_5_8_3_14_8/asyn-4-36/db/asynRecord.db",
"P=quadEMTest:, R=asyn1,PORT=IP_TetrAMM,ADDR=0,OMAX=256,IMAX=256")
drvTetrAMMConfigure("TetrAMM", "IP_TetrAMM", 10000)
dbLoadRecords("/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/db/TetrAMM.template",
"P=quadEMTest:, R=TetrAMM:, PORT=TetrAMM")
< /epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/iocBoot/commonPlugins.cmd
epicsEnvSet("T1", "Current1")
epicsEnvSet("T2", "Current2")
epicsEnvSet("T3", "Current3")
epicsEnvSet("T4", "Current4")
epicsEnvSet("T5", "SumX")
epicsEnvSet("T6", "SumY")
epicsEnvSet("T7", "SumAll")
epicsEnvSet("T8", "DiffX")
epicsEnvSet("T9", "DiffY")
epicsEnvSet("T10", "PosX")
epicsEnvSet("T11", "PosY")
# Create 11 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "TetrAMM", 0, 0, 0)
terminate called after throwing an instance of 'ParamValNotDefined'
what(): paramVal::getInteger value not defined
Aborted (core dumped)
Thank you for your attention,
Rong
- RE: quadEM-R7-0 ParamValNotDefined Mark Rivers via Tech-talk
RE: sscan mda format convert Mark Rivers via Tech-talk
<2023>
Agilent analytics devices like GCs (gas chromatography) integration into EPICS framework? Heinz Junkes via Tech-talk
<2023>
