1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Steps for installing any EPICS Device Support module
From: Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Wed, 20 Dec 2023 08:53:06 +0100
Hello Ralph, thanks for your response.
In that case, I understand that I have to use the binaries of the EPICS Support Module instead of the ones from EPICS Base.
However, what happens if I want to use, with the same PVs, EPICS Base and the EPICS Support Module? Or, for instance, two different EPICS Modules with the same PVs?
I've to use a RELEASE.local file, but what do I have to write on it and in which location should reside in order to use EPICS Base and the modules together?
Thanks, Eusebio.
Saludos/Best regards
MSc. Data Science and Computer Engineering
[email protected]
El 2023-12-19 17:13, Ralph Lange escribió:
On Tue, 19 Dec 2023 at 11:36, Eusebio Naif Al-Soliman Fuentes via Tech-talk
<[email protected]> wrote:
Hello everyone.
I have a question: How do you install an EPICS Device Support module?
Currently, I've successfully compiled both modules in their respectives
directories by defining the $EPICS_BASE environment variable inside the
configure/RELEASE file. However, what I aim to do is install the module
within the $EPICS_BASE/module directory, allowing me to launch the IOC
directly with the "softIoc" or the "softIocPVA" commands.
Don't do that.
The modules subdirectory in Base is intended for the modules that are part
of EPICS Base - it is NOT the right place for external Support modules. The
softIoc... binaries are exactly that: a soft IOC binary only containing the
stuff from Base, without external support modules.
EPICS Support modules are intended to reside next to each other, just like
you seemingly did with your mentioned modules.
You can configure the whole group by putting a file RELEASE.local in the
location where all your support modules are located - that way you don't
have to change the RELEASE files inside the modules.
Such a bundle of support modules is usually shared within an installation.
Often on a network drive, sometimes installed as system packages.
Your IOC application modules, which are technically very similar, are in a
separate place, where you keep your applications. IOC applications create
the binaries for IOC and their databases. IOC applications use the things
(libraries, template databases, etc.) provided by support modules. An
bundle of IOC applications gets the locations of the support modules
through a RELEASE.local file in the directory above. (Which often is a copy
of the file in the support area.)
Cheers,
~Ralph
Re: Steps for installing any EPICS Device Support module Ralph Lange via Tech-talk
Steps for installing any EPICS Device Support module Eusebio Naif Al-Soliman Fuentes via Tech-talk
Prev: Re: quadEM-R7-0 ParamValNotDefined Rong Huang via Tech-talk
Next: Re: Steps for installing any EPICS Device Support module Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Steps for installing any EPICS Device Support module Ralph Lange via Tech-talk
