Hi Abdalla,
We have been using Zynqs (Microzed, Picozed and a custom board) for several years now to interface our in-house detector systems. We use the FPGA fabric for time-critical interactions with custom ASICs, and the Arm to implement EPICS. We run Debian on the
Arm, so we have access to all of it's capabilities. We build the applications natively on the processor system. We also have implemented a fabric-only UDP system, so we can stream out high-speed data independently of the processor.
Pete.
Hi Abdalla,
As Tim mentioned, PandABox has a similar approach of running FPGA code and a server on a Xilinx Zynq, but we decided against putting EPICS on the Zynq chip itself. This was because it is a collaboration with SOLEIL who run Tango, so we needed an intermediate
server layer anyway, and also because we wanted to do HDF writing, which is better done on a separate PC. The architecture we now have is a TCP server that runs on the box and does the translation of registers to sensible names and data streaming, then EPICS
or Tango servers which run on a separate PC and talk to that server:
The reasons for using an FPGA over a processor was to do encoder capture and trigger pulse generation
with low and deterministic latency. We use the Xilinx tools (Vivado and the Xilinx provided kernel), and run the server process on the ARM core in a busybox-based Linux distribution.
Tom
Hi Abdalla,
We haven't installed EPICS actually on an FPGA, but rather alongside an FPGA. We needed simple custom electronics for things like tracking encoders and generating triggers as a function of encoder positions, and we wanted close coordination between the FPGA
stuff and EPICS. We use the Xilinx Zynq chip, in the form of the MicroZed. The tools are Xilinx Vivado, PetaLinux, and High Level Synthesis. The processor is a two-core ARM processor on the Zynq chip, which has good links to the FPGA.
and here
which also uses a Zynq chip.
Tim Mooney ( [email protected]) (630)252-5417
Beamline Controls Group (http://www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Hi
I would like to hear about experiences involving installing EPICS on an FPGA, mainly the following:
A brief idea about the control system involved and why an FPGA implementation was better.
What was the hardware platform used? Xilinx, Intel, etc.
What software tools used? Vendor-specific (Xilinx Vivado, Intel Quartus, etc.) or 3rd party tools were used?
What soft processor was used? Or an SoC-FPGA was used?
We have a control system running on an old PowerPC CPU with a deterministic fiber-optic interface and I am researching the idea of implementing it on FPGA.
Thanks for any insight.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
[email protected]
www.sesame.org.jo
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify
us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
- EPICS on FPGA Abdalla Ahmad via Tech-talk
- Re: EPICS on FPGA Mooney, Tim M. via Tech-talk
- Re: EPICS on FPGA Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: Issue with Stream Device. Timeout only on Reconnect Zimoch Dirk via Tech-talk
Re: EPICS on FPGA Hill, Jeff via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
