Hey,
in our project, we are using systemd and journald for storing the logs,
by specifying '--logfile=-' in our procServ options.
Then, we use Loki[1] as log server, and Promtail[2] to upload the
journald logs to the Loki server.
If you use Docker, you can use the Docker driver[3].
[1]: https://grafana.com/oss/loki/
[2]: https://grafana.com/docs/loki/latest/send-data/promtail/
[3]: https://grafana.com/docs/loki/latest/send-data/docker-driver
It works quite well, you can set up alerts, and you also get the logs
of other systemd services. Useful for debugging if something goes
wrong.
Have a great day!
Rémi NICOLE <[email protected]>
CEA/DRF/IRFU/DIS/LDISC
On Fri, 2024-01-26 at 16:02 +0100, Dr. Simon Friederich via Tech-talk
wrote:
> Dear EPICS community,
> I am currently investigating what options I have for storing the
> logs from our IOCs centrally.
> I have set up a syslog-ng docker container for testing purposes.
> The host server has the IP 10.32.240.32, the docker container has
> published ports 514 (UDP), 601 (TCP).
> For testing purposes, I used a client in the same subnet with the
> command
> logger -n 10.32.240.32 "my_message"
> successfully left a message.
> Now I have set the environment variables (on the client) in epics-
> base/configure/CONFIG_SITE_ENV.
> EPICS_IOC_LOG_INET=10.32.240.32
> EPICS_IOC_LOG_PORT=601
> In a simple test IOC on the client, I say
> iocLogInit()
> and get the message
> epics> log client: connected to log server at '10.32.240.32:601'
> I now wanted to test whether I can send a message with errlog:
> epics> errlog("my message")
> However, after a short time (some seconds) I get:
> epics> log client: lost contact with log server at
> '10.32.240.32:601'
> because "Broken pipe"
> Then a short time later the IOC reconnects to the log server.
> Have I overlooked something in the configuration?
> I am also open to alternatives (e.g. logstash?).
> Many thanks and best regards
> Simon
- IOC Logging Dr. Simon Friederich via Tech-talk
Re: Seeking EPICS Database (.db) File Parser/Generator NICOLE Remi via Tech-talk
Re: Seeking EPICS Database (.db) File Parser/Generator Ralph Lange via Tech-talk
<2024>
2025
2026
Re: External: IOC Logging Niko Kivel via Tech-talk
OpenSSL vulnerability epics Hermann, Raphael P. via Tech-talk
<2024>
2025
2026
