1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: New areaDetector releases
Date: Fri, 9 Feb 2024 22:32:30 +0000
Folks,
There are new releases of ADCore and ADSpinnaker.
ADCore R3-13.  Release notes:
NDArrayPool
·         Provide a mechanism to override the default memory allocator for NDArrays. Thanks to Emilio PJ on Github for this.
asynNDArrayDriver
·         Added UpdateTimeStamps method.
·         Added NDFileFreeCapture parameter to manually free the capture buffer.
·         Allow the filename in readNDAttributes file to be an XML string rather than a file name. This allows Channel Access clients to write the XML directly. Thanks to Marcell Nagy for this.
NDAttribute
·         Added support for attribute type CONST, where the value is the "source" value specified in the XML file. Thanks to Keenan Lang for this.
NDPluginFile
·         Change capture buffer to use std::vector which is simpler and cleaner.
·         Free capture buffer when capture or streaming start to prevent memory leak.
·         Added FreeCapture record to manually free the capture buffer.
·         Include the interface and interrupt masks passed to the constructor in the masks passed to NDPluginDriver.
NDFileNexus
·         Set the plugin type.
NDPluginBadPixel
·         Fix missing argument to constructor from configuration command.
NDPluginProcess
·         Improved the logic for high and low clipping so that both the threshold and the replacement value can be independently specified. Previously these were always the same value.
o    LowClip has been renamed to LowClipThresh.
o    HighClip has been renamed to HighClipThresh.
o    LowClipValue and HighClipValue have been added.
o    This change is not backwards compatible, the value of Low/HighClipValue must now be specified.
commonDriverMakefile, commonLibraryMakefile
·         Fix error in upper/lower case of NeXus_DIR.
·         Fix error with nanohttp_stream library.
Continuous integration
·         Added Github Actions builds. Thanks to Ralph Lange and Michael Davidsaver for this.
validateXML.sh
·         Fix location of iocimDetector.
EXAMPLE_commonPlugins.cmd
·         Load NDPluginPva by default.
·         Fix path to support module .template and .req files to be (MODULE)/db rather than (MODULE)/moduleApp/Db.
ADSpinnaker R3-5  Release Notes:
  • Updated Spinnaker version from 3.1.0.79 to 4.0.0.116 on Windows and Linux.
    • Windows users will need to update their local install of the Spinnaker SDK to this version.
    • There is a known problem on CentOS 9. The maximum number of driver buffers that Spinnaker will allow is 3. This is not a problem on Ubuntu 22 where a value over 200 is allowed on my system. Even with the limit of 3 I am able to stream the full 163 frame/s on a GS3-U3-23S6M camera. FLIR is aware of the issue.
  • Fixed a problem with stream statistics introduced in R3-4. Some of the new statistics are not available on all cameras, for example USB vs GigE. The driver was printing many error messages when a statistic was not supported.
Prev: Re: [EXTERNAL] CSS Phoebus Actions Hartman, Steven via Tech-talk
Next: RE: StreamDevice (streamCore::readCallback called unexpectedly) Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
