1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Building an IOC using synApp_6_1 on centos 7.
From: Qing Ma via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 19 Feb 2024 22:33:27 +0000
Hi All, I try to make synApp_6_1 work on centos 7. I encountered these error messages. The ioc5bmaVX_registerRecordDeviceDriver part appears at the end of Makefile under /src. I also attched the "make" output file. It will be greatly
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi All,
   I try to make synApp_6_1 work on centos 7. I encountered these error messages. The ioc5bmaVX_registerRecordDeviceDriver part appears at the end of Makefile  under /src. I also attched the "make" output file. It will be greatly appreciated if someone can help me out and also let me know any other infos you need.
Qing Ma
at DND-CAT/APS
/bin/sh: line 1: 18229 Segmentation fault      /APSshare/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9.4/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/vxWorks -I/APSshare/epics/base-3.15.6/include -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include -I/APSshare/epics/synApps_6_1/support/std-R3-6/include -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/wrn/coreip -MM ioc5bmaVX_registerRecordDeviceDriver.cpp > ioc5bmaVX_registerRecordDeviceDriver.d
make[3]: *** [ioc5bmaVX_registerRecordDeviceDriver.o] Segmentation fault
make[2]: *** [install.vxWorks-ppc32] Error 2
make[1]: *** [src.install] Error 2
make: *** [5bmaApp.install] Error 2
make -C ./configure install
make[1]: Entering directory `/home/bl5bm/epics/5bma/configure'
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32-debug ../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf-debug ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/bl5bm/epics/5bma/configure/O.linux-x86_64'
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/convertRelease.pl checkRelease
perl -CSD /APSshare/epics/synApps_6_1/support/asdStd-3-18-asd1/bin/linux-x86_64/copyAndReplace.pl _ASDSTD_ /APSshare/epics/synApps_6_1/support/asdStd-3-18-asd1 \
_EPICS_BASE_ /APSshare/epics/base-3.15.6  /APSshare/epics/synApps_6_1/support/asdStd-3-18-asd1/templates/siocAsdLaunch ../../templates/siocAsdLaunch
make[2]: Leaving directory `/home/bl5bm/epics/5bma/configure/O.linux-x86_64'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32 install
make[2]: Entering directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32'
make[2]: Leaving directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32'
make -C O.vxWorks-ppc32-debug -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32-debug install
make[2]: Entering directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32-debug'
make[2]: Leaving directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32-debug'
make -C O.vxWorks-ppc32sf -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32sf install
make[2]: Entering directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32sf'
make[2]: Leaving directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32sf'
make -C O.vxWorks-ppc32sf-debug -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32sf-debug install
make[2]: Entering directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32sf-debug'
make[2]: Leaving directory `/home/bl5bm/epics/5bma/configure/O.vxWorks-ppc32sf-debug'
make[1]: Leaving directory `/home/bl5bm/epics/5bma/configure'
make -C ./5bmaApp install
make[1]: Entering directory `/home/bl5bm/epics/5bma/5bmaApp'
make -C ./src install
make[2]: Entering directory `/home/bl5bm/epics/5bma/5bmaApp/src'
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32-debug ../../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../..
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf-debug ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/bl5bm/epics/5bma/5bmaApp/src/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/Linux -I/APSshare/epics/base-3.15.6/include   -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include      -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include  -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include   -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include   -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include   -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include            -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include   -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include  -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include      -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include   -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include         -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include  -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include   -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include   -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include   -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include   -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include   -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include   -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include   -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include   -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include   -I/APSshare/epics/synApps_6_1/support/std-R3-6/include   -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include   -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include   -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include   -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include            -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include   -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include   -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include           -MM -MF 5bmaMain.d  ../5bmaMain.c
Creating dbd file ioc5bmaLinux.dbd
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/APSshare/epics/base-3.15.6/dbd -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/dbd -I/APSshare/epics/synApps_6_1/support/asdStd-3-18-asd1/dbd -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/dbd -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/dbd -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/dbd -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/dbd -I/APSshare/epics/synApps_6_1/support/caputRecorder-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/dac128V-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/delaygen-R1-2-1/dbd -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/dbd -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/dbd -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/dbd -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/dbd -I/APSshare/epics/synApps_6_1/support/ip-R2-20-1/dbd -I/APSshare/epics/synApps_6_1/support/ipac-2-15/dbd -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/ipUnidig-R2-11/dbd -I/APSshare/epics/synApps_6_1/support/love-R3-2-7/dbd -I/APSshare/epics/synApps_6_1/support/lua-R2-0/dbd -I/APSshare/epics/synApps_6_1/support/mca-R7-8/dbd -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/dbd -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/dbd -I/APSshare/epics/synApps_6_1/support/motor-R7-1/dbd -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/dbd -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/dbd -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/dbd -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/dbd -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/dbd -I/APSshare/epics/synApps_6_1/support/std-R3-6/dbd -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/dbd -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/dbd -I/APSshare/epics/synApps_6_1/support/vac-R1-9/dbd -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/dbd -I/APSshare/epics/synApps_6_1/support/Yokogawa_DAS-R2-0-1/dbd -I/APSshare/epics/synApps_6_1/support/xxx-R6-1/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/dbd -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/dbd -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/dbd -o ioc5bmaLinux.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileNexus.dbd NDFileHDF5.dbd NDFileJPEG.dbd asyn.dbd aliveSupport.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd caputRecorder.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd drvVxi11.dbd devGpib.dbd stdSupport.dbd sscanProgressSupport.dbd opticsSupport.dbd mcaSupport.dbd drvAHxxx.dbd drvTetrAMM.dbd ipSupport.dbd luaSupport.dbd modbusSupport.dbd motorSupport.dbd devAcsMotor.dbd devAerotech.dbd devAttocube.dbd devFaulhaberMotor.dbd devImsMotor.dbd devKohzuMotor.dbd devMclennanMotor.dbd devMicos.dbd devMicroMo.dbd devNewFocus.dbd devNewport.dbd devAerotechSeq.dbd devNewportSeq.dbd devOriel.dbd devPC6K.dbd devPIJena.dbd devPIMotor.dbd devSPiiPlus.dbd devSmartMotorMotor.dbd devSoftMotor.dbd devThorLabs.dbd motorSimSupport.dbd stream.dbd devIocStats.dbd iocAdmin.dbd ether_ip.dbd delaygenSupport.dbd vacSupport.dbd drvIpac.dbd ipUnidigSupport.dbd dac128VSupport.dbd ip330Support.dbd softGlueSupport.dbd softGlueZynqSupport.dbd mw100Support.dbd
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/APSshare/epics/base-3.15.6/dbd -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/dbd -I/APSshare/epics/synApps_6_1/support/asdStd-3-18-asd1/dbd -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/dbd -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/dbd -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/dbd -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/dbd -I/APSshare/epics/synApps_6_1/support/caputRecorder-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/dac128V-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/delaygen-R1-2-1/dbd -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/dbd -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/dbd -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/dbd -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/dbd -I/APSshare/epics/synApps_6_1/support/ip-R2-20-1/dbd -I/APSshare/epics/synApps_6_1/support/ipac-2-15/dbd -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/ipUnidig-R2-11/dbd -I/APSshare/epics/synApps_6_1/support/love-R3-2-7/dbd -I/APSshare/epics/synApps_6_1/support/lua-R2-0/dbd -I/APSshare/epics/synApps_6_1/support/mca-R7-8/dbd -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/dbd -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/dbd -I/APSshare/epics/synApps_6_1/support/motor-R7-1/dbd -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/dbd -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/dbd -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/dbd -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/dbd -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/dbd -I/APSshare/epics/synApps_6_1/support/std-R3-6/dbd -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/dbd -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/dbd -I/APSshare/epics/synApps_6_1/support/vac-R1-9/dbd -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/dbd -I/APSshare/epics/synApps_6_1/support/Yokogawa_DAS-R2-0-1/dbd -I/APSshare/epics/synApps_6_1/support/xxx-R6-1/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/dbd -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/dbd -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/dbd    -o ioc5bmaLinux_registerRecordDeviceDriver.cpp ../O.Common/ioc5bmaLinux.dbd ioc5bmaLinux_registerRecordDeviceDriver /home/bl5bm/epics/5bma
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/Linux -I/APSshare/epics/base-3.15.6/include   -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include      -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include  -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include   -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include   -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include   -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include            -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include   -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include  -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include      -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include   -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include         -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include  -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include   -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include   -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include   -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include   -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include   -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include   -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include   -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include   -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include   -I/APSshare/epics/synApps_6_1/support/std-R3-6/include   -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include   -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include   -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include   -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include            -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include   -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include   -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include           -MM -MF ioc5bmaLinux_registerRecordDeviceDriver.d  ioc5bmaLinux_registerRecordDeviceDriver.cpp
make[3]: Leaving directory `/home/bl5bm/epics/5bma/5bmaApp/src/O.linux-x86_64'
Installing created dbd file ../../../dbd/ioc5bmaLinux.dbd
mkdir ../../../dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/Linux -I/APSshare/epics/base-3.15.6/include   -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include      -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include  -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include   -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include   -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include   -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include            -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include   -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include  -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include      -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include   -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include         -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include  -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include   -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include   -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include   -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include   -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include   -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include   -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include   -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include   -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include   -I/APSshare/epics/synApps_6_1/support/std-R3-6/include   -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include   -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include   -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include   -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include            -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include   -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include   -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include           -c ioc5bmaLinux_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/Linux -I/APSshare/epics/base-3.15.6/include   -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include      -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include  -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include   -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include   -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include   -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include            -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include   -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include  -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include      -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include   -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include         -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include  -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include   -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include   -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include   -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include   -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include   -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include   -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include   -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include   -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include   -I/APSshare/epics/synApps_6_1/support/std-R3-6/include   -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include   -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include   -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include   -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include            -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include   -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include   -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include           -c ../5bmaMain.c
/usr/bin/g++ -o 5bma  -L/home/bl5bm/epics/5bma/lib/linux-x86_64 -L/APSshare/epics/base-3.15.6/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/Yokogawa_DAS-R2-0-1/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/alive-R1-1-1/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/asyn-R4-36/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/autosave-R5-10/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/busy-R1-7-2/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/calc-R3-7-3/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/caputRecorder-R1-7-2/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/dac128V-R2-9/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/delaygen-R1-2-1/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/etherIP-R3-2/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/ip-R2-20-1/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/ip330-R2-9/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/ipUnidig-R2-11/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/ipac-2-15/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/lua-R2-0/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/mca-R7-8/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/modbus-R3-0/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/motor-R7-1/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/optics-R2-13-3/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/seq-2-2-6/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/std-R3-6/lib/linux-x86_64 -L/APSshare/epics/synApps_6_1/support/vac-R1-9/lib/linux-x86_64 -L/APSshare/epics/base-3.15.6/lib/linux-x86_64 -Wl,-rpath,/home/bl5bm/epics/5bma/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/base-3.15.6/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/Yokogawa_DAS-R2-0-1/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/alive-R1-1-1/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/asyn-R4-36/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/autosave-R5-10/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/busy-R1-7-2/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/calc-R3-7-3/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/caputRecorder-R1-7-2/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/dac128V-R2-9/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/delaygen-R1-2-1/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/etherIP-R3-2/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/ip-R2-20-1/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/ip330-R2-9/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/ipUnidig-R2-11/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/ipac-2-15/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/lua-R2-0/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/mca-R7-8/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/modbus-R3-0/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/motor-R7-1/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/optics-R2-13-3/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/seq-2-2-6/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/std-R3-6/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/synApps_6_1/support/vac-R1-9/lib/linux-x86_64 -Wl,-rpath,/APSshare/epics/base-3.15.6/lib/linux-x86_64           -rdynamic -m64            ioc5bmaLinux_registerRecordDeviceDriver.o 5bmaMain.o    -lmw100 -lsoftGlueZynq -lsoftGlue -lip330 -ldac128V -lipUnidig -lIpac -lvac -ldelaygen -lalive -lether_ip -ldevIocStats -lstream -lParker -lSmartMotor -lThorLabs -lsoftMotor -lmotorSimSupport -lMclennan -lMicos -lMicroMo -lNewFocus -lNewport -lOriel -lPI -lPIJena -lAcs -lacsTech80 -lAerotech -lAttocube -lFaulhaber -lIms -lKohzuMotor -lmotor -lmodbus -llua -lip -lquadEM -lmca -loptics -lautosave -lscanProgress -lsscan -lbusy -lcalc -lstd -lasyn -lseq -lpv -lcaputRecorder -ldbRecStd -ldbCore -lca -lCom -lNDPlugin -lADBase -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lalive -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom  -lX11 -lXext
Installing created executable ../../../bin/linux-x86_64/5bma
mkdir ../../../bin/linux-x86_64
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/bl5bm/epics/5bma/5bmaApp/src/O.vxWorks-ppc32'
Creating dbd file ioc5bmaVX.dbd
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/APSshare/epics/base-3.15.6/dbd -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/dbd -I/APSshare/epics/synApps_6_1/support/asdStd-3-18-asd1/dbd -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/dbd -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/dbd -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/dbd -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/dbd -I/APSshare/epics/synApps_6_1/support/caputRecorder-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/dac128V-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/delaygen-R1-2-1/dbd -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/dbd -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/dbd -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/dbd -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/dbd -I/APSshare/epics/synApps_6_1/support/ip-R2-20-1/dbd -I/APSshare/epics/synApps_6_1/support/ipac-2-15/dbd -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/ipUnidig-R2-11/dbd -I/APSshare/epics/synApps_6_1/support/love-R3-2-7/dbd -I/APSshare/epics/synApps_6_1/support/lua-R2-0/dbd -I/APSshare/epics/synApps_6_1/support/mca-R7-8/dbd -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/dbd -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/dbd -I/APSshare/epics/synApps_6_1/support/motor-R7-1/dbd -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/dbd -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/dbd -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/dbd -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/dbd -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/dbd -I/APSshare/epics/synApps_6_1/support/std-R3-6/dbd -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/dbd -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/dbd -I/APSshare/epics/synApps_6_1/support/vac-R1-9/dbd -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/dbd -I/APSshare/epics/synApps_6_1/support/Yokogawa_DAS-R2-0-1/dbd -I/APSshare/epics/synApps_6_1/support/xxx-R6-1/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/dbd -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/dbd -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/dbd -o ioc5bmaVX.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileTIFF.dbd NDFileNexus.dbd NDFileHDF5.dbd NDFileJPEG.dbd asyn.dbd aliveSupport.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd caputRecorder.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd drvVxi11.dbd devGpib.dbd stdSupport.dbd sscanProgressSupport.dbd opticsSupport.dbd mcaSupport.dbd drvAHxxx.dbd drvTetrAMM.dbd ipSupport.dbd luaSupport.dbd modbusSupport.dbd motorSupport.dbd devAcsMotor.dbd devAerotech.dbd devAttocube.dbd devFaulhaberMotor.dbd devImsMotor.dbd devKohzuMotor.dbd devMclennanMotor.dbd devMicos.dbd devMicroMo.dbd devNewFocus.dbd devNewport.dbd devAerotechSeq.dbd devNewportSeq.dbd devOriel.dbd devPC6K.dbd devPIJena.dbd devPIMotor.dbd devSPiiPlus.dbd devSmartMotorMotor.dbd devSoftMotor.dbd devThorLabs.dbd motorSimSupport.dbd stream.dbd devIocStats.dbd iocAdmin.dbd ether_ip.dbd delaygenSupport.dbd vacSupport.dbd vmeVXSupport.dbd stdVXSupport.dbd ipVXSupport.dbd SIS38XXSupport.dbd mcaCanberraSupport.dbd ipUnidigSupport.dbd dac128VSupport.dbd ip330Support.dbd camacSupport.dbd devCamacSupport.dbd allenBradley.dbd devLove.dbd tyGSOctal.dbd drvIpac.dbd IP520.dbd drvGsIP488.dbd softGlueSupport.dbd devDeltaTau.dbd devOms.dbd
perl -CSD /APSshare/epics/base-3.15.6/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/APSshare/epics/base-3.15.6/dbd -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/dbd -I/APSshare/epics/synApps_6_1/support/asdStd-3-18-asd1/dbd -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/dbd -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/dbd -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/dbd -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/dbd -I/APSshare/epics/synApps_6_1/support/caputRecorder-R1-7-2/dbd -I/APSshare/epics/synApps_6_1/support/dac128V-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/delaygen-R1-2-1/dbd -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/dbd -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/dbd -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/dbd -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/dbd -I/APSshare/epics/synApps_6_1/support/ip-R2-20-1/dbd -I/APSshare/epics/synApps_6_1/support/ipac-2-15/dbd -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/dbd -I/APSshare/epics/synApps_6_1/support/ipUnidig-R2-11/dbd -I/APSshare/epics/synApps_6_1/support/love-R3-2-7/dbd -I/APSshare/epics/synApps_6_1/support/lua-R2-0/dbd -I/APSshare/epics/synApps_6_1/support/mca-R7-8/dbd -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/dbd -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/dbd -I/APSshare/epics/synApps_6_1/support/motor-R7-1/dbd -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/dbd -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/dbd -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/dbd -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/dbd -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/dbd -I/APSshare/epics/synApps_6_1/support/std-R3-6/dbd -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/dbd -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/dbd -I/APSshare/epics/synApps_6_1/support/vac-R1-9/dbd -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/dbd -I/APSshare/epics/synApps_6_1/support/Yokogawa_DAS-R2-0-1/dbd -I/APSshare/epics/synApps_6_1/support/xxx-R6-1/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/dbd -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/dbd -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/dbd -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/dbd    -o ioc5bmaVX_registerRecordDeviceDriver.cpp ../O.Common/ioc5bmaVX.dbd ioc5bmaVX_registerRecordDeviceDriver /home/bl5bm/epics/5bma
/APSshare/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9.4/x86-linux2/bin/ccppc             -DCPU=PPC32  -DvxWorks=vxWorks -include /APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/vxWorks.h    -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include    -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/vxWorks -I/APSshare/epics/base-3.15.6/include   -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include      -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include  -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include   -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include   -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include   -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include            -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include   -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include  -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include      -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include   -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include         -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include  -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include   -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include   -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include   -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include   -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include   -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include   -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include   -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include   -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include   -I/APSshare/epics/synApps_6_1/support/std-R3-6/include   -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include   -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include   -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include   -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include            -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include   -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include   -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include          -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/wrn/coreip -MM > ioc5bmaVX_registerRecordDeviceDriver.d  ioc5bmaVX_registerRecordDeviceDriver.cpp
make[3]: Leaving directory `/home/bl5bm/epics/5bma/5bmaApp/src/O.vxWorks-ppc32'
Installing created dbd file ../../../dbd/ioc5bmaVX.dbd
/APSshare/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9.4/x86-linux2/bin/ccppc             -DCPU=PPC32  -DvxWorks=vxWorks -include /APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/vxWorks.h    -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include    -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/vxWorks -I/APSshare/epics/base-3.15.6/include   -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include      -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include  -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include   -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include   -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include   -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include            -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include   -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include  -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include   -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include      -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include   -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include         -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include  -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include   -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include   -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include   -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include   -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include   -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include   -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include   -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include   -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include   -I/APSshare/epics/synApps_6_1/support/std-R3-6/include   -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include   -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include   -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include   -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include            -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include  -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include   -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include   -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include          -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/wrn/coreip -c ioc5bmaVX_registerRecordDeviceDriver.cpp
make[2]: Leaving directory `/home/bl5bm/epics/5bma/5bmaApp/src'
make[1]: Leaving directory `/home/bl5bm/epics/5bma/5bmaApp'
/bin/sh: line 1:  9850 Segmentation fault      /APSshare/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9.4/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/vxWorks -I/APSshare/epics/base-3.15.6/include -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include -I/APSshare/epics/synApps_6_1/support/std-R3-6/include -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/wrn/coreip -MM ioc5bmaVX_registerRecordDeviceDriver.cpp > ioc5bmaVX_registerRecordDeviceDriver.d
Re: Building an IOC using synApp_6_1 on centos 7. Lang, Keenan C. via Tech-talk
Prev: Re: Question regarding EPICS licenses Johnson, Andrew N. via Tech-talk
Next: Re: Building an IOC using synApp_6_1 on centos 7. Lang, Keenan C. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: EPICS Support for SMC Chillers Foster, Andrew (OBS,RAL,TEC) via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
