1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Building an IOC using synApp_6_1 on centos 7.
From: "Lang, Keenan C. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Ma, Qing" <[email protected]>
Date: Tue, 20 Feb 2024 03:03:32 +0000
If you are just looking to get this working on CentOS, then you can edit your IOC's configure/CONFIG_SITE file to set CROSS_COMPILER_TARGET_ARCHS  to an empty string. Your build issue is coming up when trying to build against the vxWorks architecture. I'm not exactly certain why that is happening, but it isn't something that you need to build.
Having the line:
CROSS_COMPILER_TARGET_ARCHS =
in your configure/CONFIG_SITE file will set things so that you only build for Linux.
Keenan
From: Tech-talk <[email protected]> on behalf of Qing Ma via Tech-talk <[email protected]>
Sent: Monday, February 19, 2024 4:33 PM
To: [email protected] <[email protected]>
Subject: Building an IOC using synApp_6_1 on centos 7.
Hi All, I try to make synApp_6_1 work on centos 7. I encountered these error messages. The ioc5bmaVX_registerRecordDeviceDriver part appears at the end of Makefile under /src. I also attched the "make" output file. It will be greatly
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi All,
   I try to make synApp_6_1 work on centos 7. I encountered these error messages. The ioc5bmaVX_registerRecordDeviceDriver part appears at the end of Makefile  under /src. I also attched the "make" output file. It will be greatly appreciated if someone can help me out and also let me know any other infos you need.
Qing Ma
at DND-CAT/APS
/bin/sh: line 1: 18229 Segmentation fault      /APSshare/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9.4/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include -I/APSshare/epics/base-3.15.6/include/compiler/gcc -I/APSshare/epics/base-3.15.6/include/os/vxWorks -I/APSshare/epics/base-3.15.6/include -I/APSshare/epics/synApps_6_1/support/alive-R1-1-1/include -I/APSshare/epics/synApps_6_1/support/asyn-R4-36/include -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/autosave-R5-10/include -I/APSshare/epics/synApps_6_1/support/busy-R1-7-2/include -I/APSshare/epics/synApps_6_1/support/calc-R3-7-3/include -I/APSshare/epics/synApps_6_1/support/camac-R2-7-1/include -I/APSshare/epics/synApps_6_1/support/dxp-R6-0/include -I/APSshare/epics/synApps_6_1/support/dxpSITORO-R1-2/include -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/iocStats-3-1-16/include -I/APSshare/epics/synApps_6_1/support/etherIP-R3-2/include -I/APSshare/epics/synApps_6_1/support/ipac-2-15/include -I/APSshare/epics/synApps_6_1/support/ip330-R2-9/include -I/APSshare/epics/synApps_6_1/support/lua-R2-0/include -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/mca-R7-8/include -I/APSshare/epics/synApps_6_1/support/measComp-R2-3/include -I/APSshare/epics/synApps_6_1/support/modbus-R3-0/include -I/APSshare/epics/synApps_6_1/support/motor-R7-1/include -I/APSshare/epics/synApps_6_1/support/optics-R2-13-3/include -I/APSshare/epics/synApps_6_1/support/quadEM-R9-2-1/include -I/APSshare/epics/synApps_6_1/support/softGlue-R2-8-2/include -I/APSshare/epics/synApps_6_1/support/softGlueZynq-R2-0-2/include -I/APSshare/epics/synApps_6_1/support/sscan-R2-11-3/include -I/APSshare/epics/synApps_6_1/support/std-R3-6/include -I/APSshare/epics/synApps_6_1/support/tpmac-3-12/include -I/APSshare/epics/synApps_6_1/support/StreamDevice-2-8-9/include -I/APSshare/epics/synApps_6_1/support/vac-R1-9/include -I/APSshare/epics/synApps_6_1/support/vme-R2-9-2/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/vxWorks -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/APSshare/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/include -I/APSshare/epics/synApps_6_1/support/seq-2-2-6/include -I/APSshare/epics/synApps_6_1/support/allenBradley-2-3/include -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h -I/APSshare/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/wrn/coreip -MM ioc5bmaVX_registerRecordDeviceDriver.cpp > ioc5bmaVX_registerRecordDeviceDriver.d
make[3]: *** [ioc5bmaVX_registerRecordDeviceDriver.o] Segmentation fault
make[2]: *** [install.vxWorks-ppc32] Error 2
make[1]: *** [src.install] Error 2
make: *** [5bmaApp.install] Error 2
Re: Building an IOC using synApp_6_1 on centos 7. Qing Ma via Tech-talk
Prev: Building an IOC using synApp_6_1 on centos 7. Qing Ma via Tech-talk
Next: Asyn connection/communication management with asynPortDriver Yann Mandza via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: Building an IOC using synApp_6_1 on centos 7. Qing Ma via Tech-talk
