1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Building synApps and Galil ok, libGalilSupport.a not found
From: Breßler, Ingo via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 23 Feb 2024 13:38:40 +0000
Hi everyone, for migrating one of our laboratory SAXS instruments to EPICS control I am testing the synApps package and figured out how to build it on a fresh Ubuntu 22 with some modifications of the newer assemble script in perl: https: //urldefense. us/v3/__https: //github. com/EPICS-synApps/assemble_synApps/pull/6__;!!G_uCfscf7eWS!b8yI9dxg3qqs46r-TWRUenNW-gJf2F7YflCLdI7KzQ6flp1MygyB2iYeVaXtr9QMmJR1XAdwPMGW0t6pBVCniUVtHWwI$
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi everyone,
https://urldefense.us/v3/__https://github.com/EPICS-synApps/assemble_synApps/pull/6__;!!G_uCfscf7eWS!b8yI9dxg3qqs46r-TWRUenNW-gJf2F7YflCLdI7KzQ6flp1MygyB2iYeVaXtr9QMmJR1XAdwPMGW0t6pBVCniUVtHWwI$
That seems to build fine except for the xxx template which complains about "No rule to make target '../../../lib/linux-x86_64/libGalilSupport.a', needed by 'xxx'". But I can't find any rule, reference or existence of a 'libGalilSupport' in the Galil module while the Galil module itself builds without errors.
Does someone have some insights on how to fix this and where to get or build a libGalilSupport (respectively, how to adjust the configuration accordingly)?
I created a build workflow on Github reproducing this, if someone is interested. With a github account you should be able to see or download the log files of the build which are stored as artifacts:
https://urldefense.us/v3/__https://github.com/BAMresearch/EPICS-synApps-assemble/actions/runs/8007124550__;!!G_uCfscf7eWS!b8yI9dxg3qqs46r-TWRUenNW-gJf2F7YflCLdI7KzQ6flp1MygyB2iYeVaXtr9QMmJR1XAdwPMGW0t6pBVCniaOPNZ01$
Thanks for any hints!
Best wishes
Ingo
Bundesanstalt für Materialforschung und -prüfung (BAM)
Dr.-Ing. Ingo Breßler
Division 6.5 Synthesis and Scattering of Nanostructures
Unter den Eichen 87
12205 Berlin
GERMANY
Phone: + 49 30 8104-3370
E-mail: ingo.bressler at bam.de
___
BAM is a senior scientific and technical federal institute with responsibility to Federal Ministry for Economic Affairs and Climate Action.
Our mission: safety in technology and chemistry. For more information, visit https://urldefense.us/v3/__https://bam.de__;!!G_uCfscf7eWS!b8yI9dxg3qqs46r-TWRUenNW-gJf2F7YflCLdI7KzQ6flp1MygyB2iYeVaXtr9QMmJR1XAdwPMGW0t6pBVCniY7VbHz2$.
Subscribe to our newsletter: https://urldefense.us/v3/__https://bam.de/newsletter__;!!G_uCfscf7eWS!b8yI9dxg3qqs46r-TWRUenNW-gJf2F7YflCLdI7KzQ6flp1MygyB2iYeVaXtr9QMmJR1XAdwPMGW0t6pBVCniTYqhCsC$
Follow us on Twitter: https://urldefense.us/v3/__https://twitter.com/BAMResearch__;!!G_uCfscf7eWS!b8yI9dxg3qqs46r-TWRUenNW-gJf2F7YflCLdI7KzQ6flp1MygyB2iYeVaXtr9QMmJR1XAdwPMGW0t6pBVCniYQ-Lbus$
Information regarding the handling of personal data at BAM can be found in our data protection declaration at https://urldefense.us/v3/__https://bam.de/datenschutz__;!!G_uCfscf7eWS!b8yI9dxg3qqs46r-TWRUenNW-gJf2F7YflCLdI7KzQ6flp1MygyB2iYeVaXtr9QMmJR1XAdwPMGW0t6pBVCniVSa8_6I$.
Prev: Re: EPICS PLC5 Support Josh Fiddler via Tech-talk
Next: GPIB connection problem with EPICS 7 Miroslaw Dach via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: RE: EPICS PLC5 Support Josh West via Tech-talk
Next: Building synApps and Galil ok, libGalilSupport.a not found Mark via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
