1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: GPIB connection problem with EPICS 7
From: Miroslaw Dach via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Fri, 23 Feb 2024 11:32:03 -0800
Hi All, We are migrating in ALS from Centos7 to RockyLinux8 and from EPICS 3 to EPICS 7. 0. 7 . One of our ioc which runs on Centos 7 EPICS 3. 15. 4 asyn4-30 runs fine and can access the GPIB devices via gpib gateways. The same ioc when converted
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi All,
We are migrating in ALS from Centos7 to RockyLinux8 and from EPICS 3 to EPICS 7.0.7 .
One of our ioc which runs on Centos 7 EPICS 3.15.4 asyn4-30 runs fine and can access the GPIB devices via gpib gateways.
The same ioc when converted to EPICS 7.0.7 with  asyn-R4-42 on RockyLinux 8
reports the problem as below:
vxi11Configure ("gpibport01","gpib01",0,0.0,"gpib0",0,0)
dbLoadRecords("db/gpibport01.db")
iocInit()
Starting iocInit
## EPICS R7.0.7
## Rev. 2023-04-14T11:21-0700
## Rev. Date build date/time:
2024/02/23 11:09:12.735 GPIB01_MX_ASYN: queueRequest failed
2024/02/23 11:09:22.730 GPIB01_MX_ASYN: special queueRequest timeout
2024/02/23 11:10:01.926 gpibport01 vxiConnectPort error gpib01 RPC: Port mapper failure - Timed out
I compiled the same code (with EPICS 7.0.7 with  asyn-R4-42) on centos7 and ran it on Centos7 and the error messages are identical.
Would that be a problem with  EPICS 7.0.7 and new asyn-R4-42 vs EPICS 3.15.4 asyn4-30 ?
Best Regards
Mirek
RE: GPIB connection problem with EPICS 7 Mark Rivers via Tech-talk
Prev: Building synApps and Galil ok, libGalilSupport.a not found Breßler, Ingo via Tech-talk
Next: RE: EPICS PLC5 Support Josh West via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: AW: Building synApps and Galil ok, libGalilSupport.a not found Mark via Tech-talk
Next: RE: GPIB connection problem with EPICS 7 Mark Rivers via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
