1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Reg : How to use custom baud rate such as 125000 for ioc running on Linux
To: Abhishek Mazumdar - STFC UKRI <[email protected]>, "[email protected]" <[email protected]>, Timo Korhonen <[email protected]>
Date: Thu, 29 Feb 2024 13:58:58 +0000
You can also use the asynRecord OPI screens to set the baud rate. Look at the description of the BAUD and LBAUD fields here: https: //epics-modules. github. io/asyn/asynRecord. html#serial-control-fields Mark From: Tech-talk <tech-talk-bounces@ aps. anl. gov>
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
From: Tech-talk <[email protected]> on behalf of Timo Korhonen via Tech-talk <[email protected]>
Sent: Thursday, February 29, 2024 3:21 AM
To: Abhishek Mazumdar - STFC UKRI <[email protected]>; [email protected] <[email protected]>
Dear Abhishek, It would be easier to help you if you can post your st. cmd and also a console log from the IOC. If your computer can communicate with the device using python and the 125000 baud rate, unless there is something special happening
Dear Abhishek,
It would be easier to help you if you can post your st.cmd and also a console log from the IOC.
If your computer can communicate with the device using python and the 125000 baud rate, unless there is something special happening in the python code, you should be able to communicate using EPICS as well. There are much better experts on this kind of issues in the community than myself, but as far as I know, the drivers do not limit the baud rate, the hardware UART does. And as you can communicate with the device, the hardware is apparently OK.
I assume you are using asyn, and your st.cmd contains something like
drvAsynSerialPortConfigure("L0", "/dev/ttyUSB0")
asynSetOption("L0", -1, "baud", "115200")
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "1")
(your setup is probably different, using 125000 as the baud rate, etc.)
The IOC console log would probably give good hints about what is going wrong.
Best regards,
Timo
From: Tech-talk <[email protected]> on behalf of Abhishek Mazumdar - STFC UKRI via Tech-talk <[email protected]>
Reply to: Abhishek Mazumdar - STFC UKRI <[email protected]>
Date: Wednesday, 28 February 2024 at 14:40
Subject: Reg : How to use custom baud rate such as 125000 for ioc running on Linux
Hello, I am running an ioc for a device in linux which supports 125000 baud rate using UART communication. The vendor of the device has provided python libraries through which I am able to communicate with the device without any issues. The
Hello,
The vendor's python libraries uses python serial package to communicate with the port /dev/ttyUSB1 (for example) using baud rate 125000.
But when I am using the baud rate 125000 in my ioc's st.cmd , I am not able to communicate with the device.
How to communicate with the device using 125000 baudrate using EPICs IOC ?
Abhishek Mazumdar
Reg : How to use custom baud rate such as 125000 for ioc running on Linux Abhishek Mazumdar - STFC UKRI via Tech-talk
Re: Reg : How to use custom baud rate such as 125000 for ioc running on Linux Timo Korhonen via Tech-talk
Prev: RE: Commands with synchronous answers from python Neidherr, Dennis Dr. via Tech-talk
Next: Re: Generating metrics for IOC applications TZVETKOV Stephane via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Reg : How to use custom baud rate such as 125000 for ioc running on Linux Timo Korhonen via Tech-talk
Next: archiver appliance quickstart installation Rong Huang via Tech-talk
