1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Practical way to force the IOC to talk with one client
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 19 Mar 2024 10:48:14 +0100
Hello Abdalla,
The details are in the CA Reference Manual (part of your EPICS Base and available on the web [1]), in the sections "EPICS Environment Variables" and "Configuring a CA Server":
EPICS_CA_SERVER_PORT configures the port number for the client library (Gateway side),
EPICS_CAS_SERVER_PORT does the same for the CA server (IOC side).
Note that for the client library, you can also add port numbers to IP addresses listed in EPICS_CA_ADDR_LIST, if the client (Gateway) should be able to talk to the "hidden" IOCs in addition to regular ones.
Note also that moving to different ports does not establish any access security, so your requirement of "only the gateway to be able to talk with the IOC" is *not* satisfied. Any client knowing the port can talk to the IOC.
Cheers,
~Ralph
Practical way to force the IOC to talk with one client Abdalla Ahmad via Tech-talk
Re: Practical way to force the IOC to talk with one client Paul Sichta via Tech-talk
Re: Practical way to force the IOC to talk with one client Ralph Lange via Tech-talk
RE: Practical way to force the IOC to talk with one client Abdalla Ahmad via Tech-talk
Prev: Archiver Appliance cluster deployment does not display identity of current node Wang, Lin via Tech-talk
Next: ODP: Keysight oscilloscope DSOX1204 EPICS Driver Mateusz Nabywaniec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: Practical way to force the IOC to talk with one client Abdalla Ahmad via Tech-talk
Next: Keysight oscilloscope DSOX1204 EPICS Driver Sandeep Kumar Malu - STFC UKRI via Tech-talk
