1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Streamdevice - record only completes processing every other activation
From: "Daykin, Evan via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 20 Mar 2024 18:11:37 +0000
I have an unusual issue I haven’t seen before. I have a mode selector, activation bo, directed through a fanout (single output with SELL), which finally sends out a read command, like this:
record(mbbo, "$(D):MODE_CMD_SWEEP"){
    field(ZRST, "Fullsweep")
    field(ZRVL, "0")
    field(ONST, "Fullsweep4") <- SELECTED
    field(ONVL, "1")
    field(TWST, "Simulsweep4")
    field(TWVL, "2")
#User presses this to execute a scan, stays high for 0.5s
record(bo, "$(D):SWEEP_CMD_EXSC"){
    field(ZNAM, "Idle")
    field(ONAM, "Sweep")
    field(HIGH, "0.5")
    field(VAL, "0")
    field(FLNK, "_$(D):SWEEP_EXSC")
record(fanout, "_$(D):SWEEP_EXSC"){
    field(SELM, "Specified")
    field(SELL, "$(D):MODE_CMD_SWEEP")
    field(LNK0, "_$(D):SWEEP_CMD_DBG")
    field(LNK1, "_$(D):SWEEP_CMD_EXSC") <- SELECTED
    field(LNK2, "_$(D):SWEEP_CMD_SIM")
record(calcout, "_$(D):SWEEP_CMD_EXSC"){
    field(DTYP, "stream")
    field(INPA, "$(D):SWEEP_CMD_EXSC")
    field(INPB, "$(D):PAT_CSET_SWEEP")
    field(CALC, "A")
    field(OOPT, "Transition To Non-zero")
    field(OUT, "@sram.proto fullsweep4($(D)) $(HOST)")
The protocol file entry looks like this:
fullsweep4{
    ReadTimeout=2000;
    InTerminator="\r\0\n\r\0\n>";
    out "fullsweep4 c %(_\$1:SWEEP_CMD_EXSC.B)#x";
    in "\r\0\n\r\0\nChip: 0\r\0\n# of Events: %(\$1:EVT_RD_CHIP0)d\r\0\nChip: 1\r\0\n# of Events: %(\$1:EVT_RD_CHIP1)d\r\0\nChip: 2\r\0\n# of Events: %(\$1:EVT_RD_CHIP2)d\r\0\nChip: 3\r\0\n# of Events: %(\$1:EVT_RD_CHIP3)d";
it wants a message of the form:
Chip: 0
# of Events: 131072
Chip: 1
# of Events: 131072
Chip: 2
# of Events: 131072
Chip: 3
# of Events: 131072
But, the last record (calcout) _SWEEP_CMD_EXSC only fires every other time I activate the bo SWEEP_CMD_EXSC, and wireshark confirms it’s only sending out the inquiry every other click as well. Setting TPRO shows:
epics> ca:daykin@diag-cam: dbProcess of '_SRAM_TEST:SWEEP_CMD_EXSC'
cbLow: dbProcess of '_SRAM_TEST:SWEEP_CMD_EXSC' <- Nothing actually happened, nothing in wireshark, readback records don’t update
cbLow: dbProcess of Active '_SRAM_TEST:SWEEP_CMD_EXSC' with RPRO=0 <- Record fired correctly, readback records update
What does this indicate? What is RPRO doing?
Thank you,
Evan
Re: Streamdevice - record only completes processing every other activation Zimoch Dirk via Tech-talk
Prev: Re: PVXS IOC Philosophy Dave Bracey via Tech-talk
Next: Re: PVXS IOC Philosophy Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: PVXS IOC Philosophy Johnson, Andrew N. via Tech-talk
Next: Re: Streamdevice - record only completes processing every other activation Zimoch Dirk via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
