1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: How can I get a PV from an external server from inside a docker container?
From: Florian Feldbauer via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Mar 2024 19:58:47 +0100
Not yet, but I might give it a try when I have some time to work on our EPICS setup again!
Am 26.03.2024 um 19:54 schrieb Johnson, Andrew N.:
Has anyone who is using Docker tried running a Channel Access name-server on the host to forward CA searches into the docker network (and maybe another one to send them out if you're running clients inside)?
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 3/26/24, 1:09 PM, "Tech-talk" <[email protected]> wrote:
Hey,
just for completeness, if you know the IP addresses of all your IOCs you can also use the default docker network and set the Environment variables
EPICS_CA_AUTO_ADDR_LIST no
EPICS_CA_ADDR_LIST <list of all CA server IP addresses>
In this case, the udp broadcast part of CA seems to be omitted and CA checks the list of IPs directly.
At least this worked in my very first tests with containerization of our clients (Archiver, Alarm system, .....)
But of course this approach is rather error prone and you need to change your config every time an IP address changes/is being added.
On the other hand, this is the only way I know of if running docker in rootless mode.
Cheers,
Florian
Am 26.03.2024 um 09:59 schrieb Carsten Winkler via Tech-talk:
Hello Dale, hello Florian,
many thanks for your helpful advises. Now I could solve the issue simply by adding "network_mode: host" to the service "epicsbase".
Now my working docker-compose.yml  looks like:
services:
    epicsbase:
       image: softioc
       container_name: epicsbase
       volumes:
          - ./epicsbase/db:/usr/local/db
       working_dir: /usr/local/epics
       command:
          - /bin/sh
          - -c
          echo start first Soft IOC
          screen -d -m /usr/local/epics/epics-base/bin/linux-x86_64/softIoc -D /usr/local/epics/epics-base/dbd/softIoc.dbd -d /usr/local/db/test.db
          tail -f /dev/null # keep alive
       network_mode: host
Best regards
Carsten
--------------------Ursprüngliche Nachricht--------------------
Von: Carsten Winkler <[email protected]>
Gesendet: Montag 25. März 2024 14:55
An: [email protected]
Betreff: How can I get a PV from an external server from inside a docker container?
Hello,
I have 3 SoftIOCs.
    1.) local host       = 193.100.100.100 with PV: "local_pv"
    2.) external host  = 192.200.200.200 with PV: "external_pv"
    3.) docker container    on local host   with PV: "docker_pv"
From local host I can read all PVs (caget local_pv external_pv docker_pv). 👍
From inside the docker container I can read the local_pv and the docker_pv
but not the external_pv. 🤔
Here is my docker compose configuration:
services:
    epicsbase:
       image: softioc
       volumes:
       command:
          - /bin/sh
          - -c
       networks:
          - ioc-net
networks:
    ioc-net:
From inside the docker container I have also already tried EPICS_CA_AUTO_ADDR_LIST / EPICS_CA_ADDR_LIST. Unfortunately without success.
With and without these environment variables I only get the local_pv and the docker_pv.
How can I also read the external_pv from inside the docker container?
Best regards
Carsten
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
NB 2/131 / Fach 125
D-44801 Bochum
Office: NB 2/134
How can I get a PV from an external server from inside a docker container? Carsten Winkler via Tech-talk
Re: How can I get a PV from an external server from inside a docker container? Carsten Winkler via Tech-talk
Re: How can I get a PV from an external server from inside a docker container? Florian Feldbauer via Tech-talk
Re: How can I get a PV from an external server from inside a docker container? Johnson, Andrew N. via Tech-talk
Prev: Re: How can I get a PV from an external server from inside a docker container? Johnson, Andrew N. via Tech-talk
Next: Re: [Ext] Re: Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: How can I get a PV from an external server from inside a docker container? Érico Nogueira Rolim via Tech-talk
