Hi Matt (and anyone else interested), We did end up getting the EM32 sensors (we got the EM32-Xe, mostly for PoE support, but I think the Le would have worked just as well in retrospect and been a bit cheaper). Implementing the EPICS monitoring has been a low priority project for me, but I finally spent a bit of time on it. I took the script you sent and adapted it so that it's using pythonSoftIOC to create the records and IOC that holds the device data, mostly because I'm much more familiar with python than EPICS. That means that everything including the IOC creation is done in a single python script. In case you're interested, I've attached the script. I did appreciate the example script, I used your esensor class, lightly modified, and it definitely saved me a lot of time in parsing the json/xml! All the best. - Jesse Jesse Hopkins, PhD Deputy Director BioCAT, Sector 18 Advanced Photon Source On Mon, Nov 13, 2023 at 12:11 PM Matt Newville <newville at cars.uchicago.edu> wrote:
import asyncio import traceback import time import json import xml.etree.ElementTree as ET from softioc import softioc, builder, asyncio_dispatcher # import cothread import requests class ESensor: """ read Esensor data, push to Epics PVs""" def __init__(self, label, url, tempc_pv, tempf_pv, humid_pv, timestamp_pv): self.label = label self.url = url # self.prefix = prefix self.format = url.split('.')[-1] self.tempf_pv = tempf_pv self.tempc_pv = tempc_pv self.humid_pv = humid_pv self.timestamp_pv = timestamp_pv if self.format == 'xml': self.tattr = "tm0" self.tunit = "tun0" self.hattr = "hu0" self.reader = ET.fromstring elif self.format == "json": self.tattr = "tmp" self.hattr = "hum" self.tunit = "tun" self.reader = json.loads def getval(self, source, attr, force_float=True): if self.format == "xml": try: val = source.find(attr).text except: val = "-1" elif self.format == "json": try: val = source.get(attr, -1.0) except: val = "-1" if force_float: try: val = float(val) except: val = -1.0 return val def read(self): resp = requests.get(self.url, timeout=0.5) tdat = self.reader(resp.content.decode("utf-8")) tunt = self.getval(tdat, self.tunit, force_float=False) tval = self.getval(tdat, self.tattr) hval = self.getval(tdat, self.hattr) return tval, tunt, hval def update(self): tval, tunit, hval = self.read() if tunit in (0, '0', 'F'): tval_f = tval tval_c = (tval - 32)*5.0/9.0 else: tval_c = tval tval_f = (tval_c * 9.0/5) + 32 tval_f = float("%.3f" % tval_f) tval_c = float("%.3f" % tval_c) hval = float("%.3f" % hval) self.tempc_pv.set(tval_c) self.tempf_pv.set(tval_f) self.humid_pv.set(hval) self.timestamp_pv.set(time.ctime()) if __name__ == '__main__': # Create an asyncio dispatcher, the event loop is now running dispatcher = asyncio_dispatcher.AsyncioDispatcher() esensors = [] # Define as prefix, url sensor_defs = [ ['18ID:EnvMon:D', "http://164.54.204.197/status.json"], ['18ID:EnvMon:C', "http://164.54.204.198/status.json"], ['18ID:EnvMon:A', "http://164.54.204.199/status.json"], ] for sensor_def in sensor_defs: prefix = sensor_def[0] url = sensor_def[1] # Set the record prefix builder.SetDeviceName(prefix) # Create some records ai_c = builder.aIn('TempC', initial_value=0, DESC='Temperature (C)') ai_f = builder.aIn('TempF', initial_value=0, DESC='Temperature (F)') ai_h = builder.aIn('Humid', initial_value=0, DESC='Humidity (percent)') si_t = builder.stringIn('TimeStamp', initial_value="", DESC='Timestamp of last update') esensor = ESensor(prefix, url, ai_c, ai_f, ai_h, si_t) esensors.append(esensor) # Boilerplate get the IOC started builder.LoadDatabase() softioc.iocInit(dispatcher) # Start processes required to be run after iocInit async def update(): while True: try: [e.update() for e in esensors] except Exception: # traceback.print_exc() pass await asyncio.sleep(0.5) dispatcher(update) # Finally leave the IOC running with an interactive shell. softioc.interactive_ioc(globals())
ANJ, 27 Mar 2024 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
