1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Alarm Handler Limitations
From: "Srinivas, Dhruv via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 5 Apr 2024 20:34:16 +0000
I am currently working on creating an alarm server for our epics IOCs and I’ve been running into a few issues in the process.
To begin with, I’ve noticed that if I add a large number of alarms (~5000 or more), it causes the initial loading process to take a significant amount of time. Often on the order of 30 minutes. I was wondering if this was expected behavior or if there are ways to reduce the load time.
Secondly, I’ve had issues connecting Phoebus to the alarm server. At the moment, I have Phoebus running on one machine and the alarm server running on another one due to various limitations. I also have kafka and zookeeper running on the same machine as the alarm server and have verified that the CLI is functioning. I was hoping someone would know how to connect Phoebus to it, as I’ve been unable to find the port it should connect to.
Sincerely,
Dhruv Srinivas
srinivas1 at llnl.gov
Re: Alarm Handler Limitations Paul Sichta via Tech-talk
Prev: Re: caPutLog breaks monitoring of PV when the same channel is used for putting Érico Nogueira Rolim via Tech-talk
Next: Re: Alarm Handler Limitations Paul Sichta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
