1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Example of using a record field from an external IOC as an INPA link on a calcout record
To: "Wlodek, Jakub" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 12 Apr 2024 18:42:18 +0000
Hi Jakub,
Do you have control over the asynPortDriver code?  If so, then I think you can do the following:
  • Add a new asynInt32 TRIGGER parameter
  • Add a new bo record myIOC:myTrigger that writes to the TRIGGER parameter
  • The PV in the external IOC can write directly to myIOC:myTrigger to send the trigger.
  • Alternatively myIOC:myTrigger.DOL can contain the name of the external PV where it gets its value.  That link can be set to CP, and it can be changed dynamically at run time.
Is this what you are looking for?
From: Tech-talk <[email protected]> On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Friday, April 12, 2024 12:17 PM
To: [email protected]
Subject: Example of using a record field from an external IOC as an INPA link on a calcout record
Hello all,
I am currently working on an interesting setup where I would like to use an external signal (i.e. PV from another IOC) within an asynPortDriver to trigger certain behavior (basically as a way to simulate hardware triggers for a device that does not allow for them).
Could anyone point me to an example database that can do something like this? I was thinking of having the external signal be either a binary or scalar signal - and write some logic for "triggering" based on rising/falling edge when using the binary signal, or with simple start/gate/step for scalars.
Also, if possible, rather than specifying the trigger source PV name as an environment variable at IOC boot, I'd be interested in being able to adjust the PV name for this INLINK dynamically, i.e. from another record in the database. I was thinking of using a stringout and an scalcout that will compose the string with the CP/NMS modifiers for INPA dynamically. Is this actually possible or is the CA link only made at iocInit()?
Jakub
Example of using a record field from an external IOC as an INPA link on a calcout record Wlodek, Jakub via Tech-talk
Prev: Example of using a record field from an external IOC as an INPA link on a calcout record Wlodek, Jakub via Tech-talk
Next: Re: Remote reset of MVME-2700 possible through serial console Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: PVXS monitor - No dependence on MPMCFIFO workqueue Eusebio Naif Al-Soliman Fuentes via Tech-talk
