1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
Date: Wed, 17 Apr 2024 17:55:21 +0000
On 10/04/2024 20:11, Mark Rivers via Tech-talk wrote:
Folks,
R1-0 of ADEuresys is now available.  ADEuresys is a driver for CoaXPress cameras using PCIe frame grabbers from Euresys.
CoaXPress is a high-speed camera interface using multiple coaxial cables.  Each cable can run up to 12.5 Gbits/s, and with 4 parallel cables the total speed is up to 50 Gbits/s.
CoaXPress is based on GenICam, so camera features are controlled the same way as with GigEVision and USBVision cameras.  The ADEuresys driver is derived from ADGenICam.
The driver has been tested on Windows 10 and Linux (CentOS 9 Stream) with the following cameras:
Model
Mikrotron EoSens 2.0MCX12
Adimec Q-12A
ViewWorks VNP604
Pixel dimensions
1920 x 1080
4096 x 3072
14192 x 10640
MegaPixels
2.1
12.6
151.0
CXP version
CXP-12 X4
CXP-6 X4
CXP-6 X4
Frames/s, Mono8
2247
187
6.5
GBytes/s. Mono8
4.66
2.35
1.0
Frames/s, Mono10
1798
152
6.2
GBytes/s. Mono10
7.46
3.83
2.0
Frames/s, Mono12
N.A
N.A
6.2
GBytes/s. Mono12
N.A
N.A
2.0
Note that the Mikrotron camera runs at 2,247 frames per second in Mono8 mode.
Home: https://github.com/areaDetector/ADEuresys
Documentation: https://areadetector.github.io/areaDetector/ADEuresys/ADEuresys.html
Regarding the file saving benchmarks, quoted below, I can confirm the presence of a global lock in libhdf5.
> I believe this indicates that the rate is limited by a global mutex in the HDF5 library, since neither plugin was CPU bound, and I don’t think they were limited by the NVMe disk write rate.
From https:// docs.hdfgroup.org/hdf5/develop/group___h5.html#ga70bfde4acd009cdd7bcd2f54c594e28a
> The HDF5 library, although not internally multi-threaded, can be built with a thread-safety feature enabled that protects internal data structures with a mutex. In certain circumstances, it may be useful to determine, at run-time, whether the linked HDF5 library was built with the thread-safety feature enabled.
From https:// forum.hdfgroup.org/t/write-separate-files-with-multithreading/11224/2
> this will give you the illusion of multiple threads writing to different files or the same file. I’m saying illusion because only one thread at a time can execute code in the HDF5 library. In other words, these threads will not be executing library code concurrently.
The recommended parallelism scheme for HDF5 is MPI, which IMHO I can only see fitting into areaDetector as some NDFileHDF5MPI plugin which would launch worker processes with mpirun and somehow feed frames to these processes. The other option I can think of, launching multiple instances of an IOC under mpirun and having a custom main() function which calls either the IOC startup function or starts an HDF5 worker based on process rank, while possible, is much more complicated, and doesn't seem scalable, since it requires changes to the main function in every IOC which needs the functionality.
Also from the benchmarks
> I found that writing files with JRaw, both in Stream mode and Capture mode, did not result in a statistically significant improvement over HDF5. In some cases it was faster, but in some it was slower.
I believe the advantage of something like JRaw over HDF5 would be that launching two instances of the plugin on the same IOC and sending frames to them using NDPluginScatter should actually benefit from using multiple threads for I/O. That scenario doesn't seem to be included in benchmark.txt. Do you think it makes sense to test it?
Cheers,
Cheers,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Mark Rivers via Tech-talk
Prev: Re: xspress3 channel numbering John Dobbins via Tech-talk
Next: RE: EPICS 7.0.8 and 7.0.7 Windows build failure Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Mark Rivers via Tech-talk
Next: Job Opportunities at the Canadian Light Source Gillian Black via Tech-talk
