1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: caput with ca_put_callback
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Hinko Kocevar <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 19 Apr 2024 15:11:28 +0200
Hej Hinko,
>can someone explain what is going on in the first case with caput >command both using ca_put_callback ?
At least I can not.
My coment would be, that the "wait/callback", the "-w" in caput, is only intended for the VAL field (or RVAL,DVAL). May be homing.
But not for STOP.
Does this help ?
BR
/Torsten
On 2024-04-19 14:30, Hinko Kocevar via Tech-talk wrote:
I'm playing around with the motor record (motorMotorSim) and how one could abort the motion in progress.
With initial position at 0 I do the following in three terminals ; executing commands one after another:
TERM1:
$ camonitor IOC:m1.RBV
IOC:m1.RBV                     2024-04-19 14:17:15.641496 0
IOC:m1.RBV                     2024-04-19 14:17:22.458046 0.02
IOC:m1.RBV                     2024-04-19 14:17:22.558330 0.09
IOC:m1.RBV                     2024-04-19 14:17:37.500906 14.99
IOC:m1.RBV                     2024-04-19 14:17:37.601177 15
TERM2:
$ caput -l -c -w 20 IOC:m1.VAL 15
Old : IOC:m1.VAL                     2024-04-19 14:17:15.641496 0
New : IOC:m1.VAL                     2024-04-19 14:17:37.601294 15
TERM3:
$ caput -l -c -w 20 IOC:m1.STOP 1
Old : IOC:m1.STOP                    2024-04-19 14:17:23.059605 0
New : IOC:m1.STOP                    2024-04-19 14:17:37.601294 0
The TERM3 caput to .STOP is waiting TERM2 caput to .VAL to finish.
If the caput command in TERM3 is not using the ca_put_callback then the motor motion is aborted immediately as seen below:
TERM1:
IOC:m1.RBV                     2024-04-19 14:24:48.447635 0
IOC:m1.RBV                     2024-04-19 14:24:54.863364 0.02
IOC:m1.RBV                     2024-04-19 14:24:54.963617 0.09
IOC:m1.RBV                     2024-04-19 14:24:57.269834 2.3
IOC:m1.RBV                     2024-04-19 14:24:57.370032 2.31
TERM2:
Old : IOC:m1.VAL                     2024-04-19 14:24:48.447635 0
New : IOC:m1.VAL                     2024-04-19 14:24:57.370032 2.31
TERM3:
$ caput -l -w 20 IOC:m1.STOP 1
Old : IOC:m1.STOP                    2024-04-19 14:24:57.069324 0
New : IOC:m1.STOP                    2024-04-19 14:24:57.085839 0
can someone explain what is going on in the first case with caput command both using ca_put_callback ?
//hinko
RE: [EXTERNAL] Re: caput with ca_put_callback Pearson, Matthew via Tech-talk
caput with ca_put_callback Hinko Kocevar via Tech-talk
Prev: caput with ca_put_callback Hinko Kocevar via Tech-talk
Next: RE: [EXTERNAL] Re: caput with ca_put_callback Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
