if you look into the Makefile of the IOC, its configured for linux-x84_64.
Are you running Linux or windows? If you are using Windows, you have to modify the Makefile accordingly.
Otherwise the envPath file will not be created.
Jörn
Am Dienstag, 30. April 2024, 12:57:28 MESZ schrieb Donny Domagoj Cosic via Tech-talk:
> Hello,
> I successfully compiled AreaDetects R3-13 and added the ADPylon option
> into the config file with the path to the Pylon SDK (v7.4.0). The
> ADPylon module was created and I followed the instructions for reading
> the XML file from a Basler Camera and created the db and adl files using
> ADGenICam.
> I modified the st.cmd file in the ADPylon IOC with the address of the
> camera I want to connect to but when I run the st.cmd file I noticed
> that the envPaths file is missing from the folder.
> Do I have to separately compile the ADPylon IOC? If I try this, I get an
> error that I am missing the Pylon library even though the path is
> defined to "/opt/pylon/". Could this be because I am using a newer
> version of Pylon SDK? Which version has been tested with this IOC?
> Additionally, after I start the IOC, how can I display the video from
> the camera in CS-Studio Pheobus?
> Thank you in advance,
- Re: AreaDetectors - ADPylon Donny Domagoj Cosic via Tech-talk
- AreaDetectors - ADPylon Donny Domagoj Cosic via Tech-talk
Re: AreaDetectors - ADPylon Wang Xiaoqiang via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
