1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: AreaDetectors - ADPylon
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>
Cc: [email protected]
Date: Tue, 30 Apr 2024 15:29:12 +0200
Hi Jörn,
Thank you for the suggestion. I am running the IOC in Linux and this is correctly configured. I was able to use Wong suggestion "make envPaths" to generate this file successfully. However I am still not able to run the st.cmd file. I get the error "syntax error near unexpected token errlogInit(20000). It seems like it is not finding EPICS_BASE.
Any suggestions?
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | https://urldefense.us/v3/__http://www.irb.hr__;!!G_uCfscf7eWS!bPN0Ned2WfQtvKasArKYVt7OYnyHqT7oxl21oKlGVXBqR3BVyooTU0CR2HINIFvtQUtW8QTJ2biLujCV6jv-mPNCR_5Wrhbr$
Dana 2024-04-30 14:31, Jörn Dreyer via Tech-talk je napisao(la):
if you look into the Makefile of the IOC, its configured for linux-x84_64.
Are you running Linux or windows? If you are using Windows, you have
to modify the Makefile accordingly.
Otherwise the envPath file will not be created.
Jörn
Am Dienstag, 30. April 2024, 12:57:28 MESZ schrieb Donny Domagoj Cosic
via Tech-talk:
Hello,
I successfully compiled AreaDetects R3-13 and added the ADPylon option
into the config file with the path to the Pylon SDK (v7.4.0). The
ADPylon module was created and I followed the instructions for reading
the XML file from a Basler Camera and created the db and adl files using
ADGenICam.
I modified the st.cmd file in the ADPylon IOC with the address of the
camera I want to connect to but when I run the st.cmd file I noticed
that the envPaths file is missing from the folder.
Do I have to separately compile the ADPylon IOC? If I try this, I get an
error that I am missing the Pylon library even though the path is
defined to "/opt/pylon/". Could this be because I am using a newer
version of Pylon SDK? Which version has been tested with this IOC?
Additionally, after I start the IOC, how can I display the video from
the camera in CS-Studio Pheobus?
Thank you in advance,
Re: AreaDetectors - ADPylon Mark Rivers via Tech-talk
AreaDetectors - ADPylon Donny Domagoj Cosic via Tech-talk
Re: AreaDetectors - ADPylon Jörn Dreyer via Tech-talk
Prev: Re: AreaDetectors - ADPylon Jörn Dreyer via Tech-talk
Next: Re: RE: Question about PV value from epics ioc Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: AreaDetectors - ADPylon Mark Rivers via Tech-talk
