1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: RE: Channelfinder Recsync Client: Limit records client side
From: "Kenner, Daniel Craig via Tech-talk" <[email protected]>
To: Tynan Ford <[email protected]>
Date: Thu, 9 May 2024 22:46:44 +0000
Hey Tynan, thanks for getting back to me.
Indeed, after I sent my email yesterday, I tore into the Recsync Client module and discovered much the same. Unfortunately, we can’t limit it at the cfstore level as the client oversees setting up the recsync server and I can’t hand them a precompiled version.
Given these restrictions I have created my own version that injects a field parser in the function where the recsync client pushes to the server. It scans the info fields and only allows the record to be sent if it has a specific info(key, value) pair. Additionally, I edited the caster struct to include a field you set in the st.cmd file to enable this behavior.
My current solution is a little bit janky, but I think with some polish it could be a real a useful addition. Do you happen to know who I should contact if to discuss getting this included in the Recsync Module on Git? Unclear on who owns the repo.
Sent: Thursday, May 9, 2024 3:25 PM
To: Kenner, Daniel Craig <[email protected]>
Cc: [email protected]
Subject: Re: Channelfinder Recsync Client: Limit records client side
Hi Daniel,
I am not aware of any field like that but it does sound like an interesting idea. Another place you could filter PVs before they reach channel finder is on the recceiver side, in the cfstore plugin.
Best,
Tynan
On Wed, May 8, 2024 at 6:32PM Kenner, Daniel Craig via Tech-talk <[email protected]> wrote:
Hello all,
I have been working with LLNL on an EPICs application. The Channelfinder has critical functionality we would like to take advantage of, but one of the hurdles is limiting what records are allowed to be published through the reccaster module. I don’t want the end user to have visibility into every single record an IOC has, but I am unclear if the support module offers this functionality. Is there some field I can add to relevant records so that reccaster only publishes those PV’s?
Thank you for your time,
Daniel Kenner
Computer Engineer
Lawrence Livermore National Laboratory
Phone: (925) 758-2607
Email: [email protected]
Channelfinder Recsync Client: Limit records client side Kenner, Daniel Craig via Tech-talk
Re: Channelfinder Recsync Client: Limit records client side Tynan Ford via Tech-talk
Prev: Re: Channelfinder Recsync Client: Limit records client side Tynan Ford via Tech-talk
Next: Re: Channelfinder Recsync Client: Limit records client side Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
