1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time.
To: Yann Mandza <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 11 May 2024 18:05:37 +0000
Hi Yann,
I have looked at devAsynFloat64 and it never sets the record .time field for ao records, only for ai records.  So you have found a bug, and TSE=-2 does not currently work for output records.  I will fix that.  It is almost certainly also a problem with asynInt32, asynIUnt32Digital and asynOctet device support as well.
Meanwhile you could put an ai RBV record with SCAN=I/O Intr which should get your hardware's timestamp for that same parameter.
Sent: Saturday, May 11, 2024 12:46 PM
To: Mark Rivers <[email protected]>; Torsten Bögershausen <[email protected]>; [email protected] <[email protected]>
Subject: RE: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time.
Mark,
I meant that a added some debug print lines to see the content of that time variable in devAsynFloat64 as:
static const char *functionName="processCallbackOutput";
printf( "\033[0;33m%s : ( %s ) : time: '%u'\n\033[0m", epicsThreadGetNameSelf( ), __FUNCTION__, pPvt->pasynUser->timestamp.nsec );
and inside my driver writeFloat64 as below:
epicsTimeGetCurrent( &timeStamp  );
setTimeStamp( &timeStamp );
printf( "\033[0;33m%s : ( %s ) : time: '%u'\n\033[0m", epicsThreadGetNameSelf( ), __FUNCTION__, timeStamp.nsec );
just mentioned it so that the logs I shared would make sense. Not consequential though.
I also tried this method.
asynRegisterTimeStampSource("ETHHAL ", "myTimeStampSource") after registering a timestamp method and adding these lines
to my write method.
updateTimeStamp (&timeStamp);
here are some logs.
ETHHAL : ( processCallbackOutput ) : time: '0'
ETHHAL : ( myTimeStampSource ) : time: '813505109'
ETHHAL : ( writeFloat64 ) : time: '813505109'
2024/05/11 19:41:12.814 ETHHAL:writeFloat64: function=0, value=4.000000
2024/05/11 19:41:12.814 DRVASYN:MOD0-VoltageRamp devAsynFloat64::processCallbackOutput process value 4.000000
Still undefined time.
Yann
Sent: Saturday, May 11, 2024 7:33 PM
To: Yann Mandza <[email protected]>; Torsten Bögershausen <[email protected]>; [email protected]
·                // Added a print line in devAsynFloat64 processCallbackOutput and writeFloat64 for some info on the time variable.
Please show those lines of code, since I don't know what you mean by the "time variable".
Sent: Saturday, May 11, 2024 12:22 PM
Hey Mark,
> What do you observe with the code you showed in the last message?
Here are some logs,
caput DRVASYN:MOD0-VoltageRamp 4
Old : DRVASYN:MOD0-VoltageRamp 0
New : DRVASYN:MOD0-VoltageRamp 4
ETHHAL : ( writeFloat64 ) : time: '169054678'
2024/05/11 19:15:20.169 ETHHAL:writeFloat64: function=0, value=4.000000
2024/05/11 19:15:20.169 DRVASYN:MOD0-VoltageRamp devAsynFloat64::processCallbackOutput process value 4.000000
caget -a DRVASYN:MOD0-VoltageRamp
DRVASYN:MOD0-VoltageRamp <undefined> 4
Yann
Sent: Saturday, May 11, 2024 7:13 PM
Sent: Saturday, May 11, 2024 11:50 AM
To: Torsten Bögershausen <[email protected]>; [email protected] <[email protected]>; Mark Rivers <[email protected]>
Hey Torsten, Mark pitched in, but I forgot to add you in my response.
> Do you call setTimeStamp() ?
Here the implementation for my write method. Testing for normal async with caput first.
asynStatus drvAsynIsegHalService::writeFloat64( asynUser *pasynUser, epicsFloat64 value )
  static const char *functionName = "writeFloat64";
  const char *propertyName;
  epicsTimeStamp timeStamp;
  char sVal[WRITE_BUF_LEN];
  int function = pasynUser->reason;
  asynStatus status = asynSuccess;
  epicsSnprintf( sVal, WRITE_BUF_LEN, "%f", value );
/*call driver methods and return asynError if write operation fails*/
// Get current IOC time.
// tried this without success.
setTimeStamp(&timeStamp);
  // update value of parameter
  status = ( asynStatus ) setDoubleParam( function, value );
  status = ( asynStatus ) callParamCallbacks( );
  if( status )
    epicsSnprintf( pasynUser->errorMessage, pasynUser->errorMessageSize,
                   "%s:%s: status=%d, function=%d, value=%f",
                   session_, functionName, status, function, value );
  else
    asynPrint( pasynUser, ASYN_TRACEIO_DEVICE,
               "%s:%s: function=%d, value=%f\n",
              session_, functionName, function, value );
  return status;
Yann
-----Original Message-----
Sent: Saturday, May 11, 2024 4:57 PM
To: Yann Mandza <[email protected]>; [email protected]
On 2024-05-11 13:39, Yann Mandza via Tech-talk wrote:
> Dear all,
> I am working onan Asyn Port driver using with asynR4-42 on a Linux
> machine. Am trying to add timing support for Output record using
> TSE=-2 and
> and info(asyn:READBACK, "1"). When I caget an output PV with TSE=-2
> after caput to it the time obtained is <undefined> though the value is
> well written to the device.
> A camonitor on a PV with TSE=-2 and info(asyn:READBACK, "1") show an
> <undefined> time too though the read value is correct. I would like to
> associate the device timestamp to the record for output readback, and
> the current time return by epicsTimeGetCurrent to the record after a
> caput. In my poller thread this is how I set the time stamp:
> epicsUInt32 seconds = 0;
> epicsUInt32 microsecs = 0;
> epicsTimeStamp time;
> sscanf( timeStampLastChanged/*hardware time string*, "%u.%u",
> &seconds, &microsecs ) != 2 )
> time.secPastEpoch = seconds - POSIX_TIME_AT_EPICS_EPOCH;
> time.nsec = microsecs * 100000;
> pasynUser->timestamp = time;
RE: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time. Yann Mandza via Tech-talk
Re: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time. Torsten Bögershausen via Tech-talk
Re: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time. Mark Rivers via Tech-talk
Prev: RE: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time. Yann Mandza via Tech-talk
Next: RE: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time. Yann Mandza via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
