Mark,
I have looked at devAsynFloat64 and it never sets the record .time field for ao records, only for ai records. So you have found a bug, and TSE=-2 does not currently work for output records. I will fix that. It is
almost certainly also a problem with asynInt32, asynIUnt32Digital and asynOctet device support as well.
Oh well! then, it was worth reporting my issue to the community.
Meanwhile you could put an ai RBV record with SCAN=I/O Intr which should get your hardware's timestamp for that same parameter
Yes, I indeed provide I/O Intr Input records for those output records that are not using the ‘info(asyn:READBACK, "1")’ and
the timestamp is correct there.
though I did use this format
‘pasynUser->timestamp = time’ in the poller thread. Gonna test with setTimeStamp and see.
Thanks again for your assistance. I’ll wait for when you would update Asyn.
Yann
will fix that. It is almost certainly also a problem with asynInt32, asynIUnt32Digital and asynOctet device support as well.
Meanwhile you could put an ai RBV record with SCAN=I/O Intr which should get your hardware's timestamp for that same parameter.
Mark,
I meant that a added some debug print lines to see the content of that time variable in
devAsynFloat64 as:
static const char *functionName="processCallbackOutput";
printf( "\033[0;33m%s : ( %s ) : time: '%u'\n\033[0m", epicsThreadGetNameSelf( ), __FUNCTION__, pPvt->pasynUser->timestamp.nsec );
and inside my driver writeFloat64 as below:
epicsTimeGetCurrent( &timeStamp );
setTimeStamp( &timeStamp );
printf( "\033[0;33m%s : ( %s ) : time: '%u'\n\033[0m", epicsThreadGetNameSelf( ), __FUNCTION__, timeStamp.nsec );
just mentioned it so that the logs I shared would make sense. Not consequential though.
I also tried this method.
asynRegisterTimeStampSource("ETHHAL ", "myTimeStampSource") after registering a timestamp method and adding these lines
to my write method.
updateTimeStamp (&timeStamp);
here are some logs.
ETHHAL : ( processCallbackOutput ) : time: '0'
ETHHAL : ( myTimeStampSource ) : time: '813505109'
ETHHAL : ( writeFloat64 ) : time: '813505109'
2024/05/11 19:41:12.814 ETHHAL:writeFloat64: function=0, value=4.000000
2024/05/11 19:41:12.814 DRVASYN:MOD0-VoltageRamp devAsynFloat64::processCallbackOutput process value 4.000000
Still undefined time.
Yann
// Added a print line in devAsynFloat64 processCallbackOutput and writeFloat64 for some info on the time variable.
Please show those lines of code, since I don't know what you mean by the "time variable".
Hey Mark,
What do you observe with the code you showed in the last message?
Here are some logs,
caput DRVASYN:MOD0-VoltageRamp 4
Old : DRVASYN:MOD0-VoltageRamp 0
New : DRVASYN:MOD0-VoltageRamp 4
ETHHAL : ( writeFloat64 ) : time: '169054678'
2024/05/11 19:15:20.169 ETHHAL:writeFloat64: function=0, value=4.000000
2024/05/11 19:15:20.169 DRVASYN:MOD0-VoltageRamp devAsynFloat64::processCallbackOutput process value 4.000000
caget -a DRVASYN:MOD0-VoltageRamp
DRVASYN:MOD0-VoltageRamp <undefined> 4
Yann
Hey Torsten, Mark pitched in, but I forgot to add you in my response.
> Do you call setTimeStamp() ?
Here the implementation for my write method. Testing for normal async with caput first.
asynStatus drvAsynIsegHalService::writeFloat64( asynUser *pasynUser, epicsFloat64 value )
static const char *functionName = "writeFloat64";
const char *propertyName;
epicsTimeStamp timeStamp;
char sVal[WRITE_BUF_LEN];
int function = pasynUser->reason;
asynStatus status = asynSuccess;
epicsSnprintf( sVal, WRITE_BUF_LEN, "%f", value );
/*call driver methods and return asynError if write operation fails*/
// tried this without success.
setTimeStamp(&timeStamp);
// update value of parameter
status = ( asynStatus ) setDoubleParam( function, value );
status = ( asynStatus ) callParamCallbacks( );
epicsSnprintf( pasynUser->errorMessage, pasynUser->errorMessageSize,
"%s:%s: status=%d, function=%d, value=%f",
session_, functionName, status, function, value );
asynPrint( pasynUser, ASYN_TRACEIO_DEVICE,
"%s:%s: function=%d, value=%f\n",
session_, functionName, function, value );
-----Original Message-----
Sent: Saturday, May 11, 2024 4:57 PM
To: Yann Mandza <[email protected]>;
[email protected]
Subject: Re: Output record with TSE=-2 and info(asyn:READBACK, "1") returns <undefined> time.
On 2024-05-11 13:39, Yann Mandza via Tech-talk wrote:
> I am working onan Asyn Port driver using with asynR4-42 on a Linux
> machine. Am trying to add timing support for Output record using
> and info(asyn:READBACK, "1"). When I caget an output PV with TSE=-2
> after caput to it the time obtained is <undefined> though the value is
> well written to the device.
> A camonitor on a PV with TSE=-2 and info(asyn:READBACK, "1") show an
> <undefined> time too though the read value is correct. I would like to
> associate the device timestamp to the record for output readback, and
> the current time return by epicsTimeGetCurrent to the record after a
> caput. In my poller thread this is how I set the time stamp:
> epicsUInt32 seconds = 0;
> epicsUInt32 microsecs = 0;
> sscanf( timeStampLastChanged/*hardware time string*, "%u.%u",
> &seconds, µsecs ) != 2 )
> time.secPastEpoch = seconds - POSIX_TIME_AT_EPICS_EPOCH;
> time.nsec = microsecs * 100000;
> pasynUser->timestamp = time;
