1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: EPICS and EPICS+PVXS internal threading of IOCs
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 17 May 2024 10:45:15 +0200
That is more or less the basic setup.
Note that there are already network specific threads in this list, which are generated per network interface configured.
When EPICS network connections are active, the server(s) on the IOC will usually start one pair of threads per client.
If your IOC uses the parallel callback threads functionality (to utilize parallel processing on multiple CPUs), there will be (highly configurable) more instances of the cbLow/cbMedium/cbHigh threads.
Many drivers and device support modules start their own threads. ASYN ports often have a thread associated with each port, AreaDetector plugins (as they are implemented as ASYN ports) most often start a thread per plugin.
MCoreUtils is a module that you can use to have more control over priorities, scheduling mechanisms and CPU allocation of IOC threads. This is convenient when you're running real-time applications on the same host and want to keep the IOC from running on your dedicated real-time core(s). (Except maybe for that one device support thread that does the communication between the IOC and the real-time parts...)
Cheers,
~Ralph
Re: EPICS and EPICS+PVXS internal threading of IOCs Joao Paulo Martins via Tech-talk
EPICS and EPICS+PVXS internal threading of IOCs Dave Bracey via Tech-talk
Re: EPICS and EPICS+PVXS internal threading of IOCs Mark Rivers via Tech-talk
Prev: Re: EPICS and EPICS+PVXS internal threading of IOCs Mark Rivers via Tech-talk
Next: ADUrl and digest authentication Tomasz Brys via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: EPICS and EPICS+PVXS internal threading of IOCs Joao Paulo Martins via Tech-talk
