1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: Changing runtime limits with Channel Access
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 20 May 2024 14:08:18 +0200
Also keep in mind that the ao record has two sets of range/limits fields.
HOPR/LOPR - "Operating Range" - hints for clients (like Phoebus) how to display things.
DRVH/DRVL - "Drive Limits" - these limits are clipping the output value that the record will write.
Depending on your specific use case and application, you might want to set both to the same value, or both to different values, or only one, or only the other one. (Or none, for completeness.)
Cheers,
~Ralph
RE: Changing runtime limits with Channel Access Alessandra Palazzo via Tech-talk
Re: Changing runtime limits with Channel Access Ulrik Pedersen via Tech-talk
Prev: Re: Changing runtime limits with Channel Access Ulrik Pedersen via Tech-talk
Next: JavaFX Phoebus warning at run time William F Badgett Jr via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: RE: Changing runtime limits with Channel Access Alessandra Palazzo via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
