1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: PyDevice support VAL field remains 1
From: Vishnu Patel via Tech-talk <tech-talk at aps.anl.gov>
To: "Tech Talk (tech-talk at aps.anl.gov)" <Tech-talk at aps.anl.gov>
Date: Fri, 24 May 2024 06:21:25 +0000
     I have developed IOC using PyDevice.  The ao recored works functionally with python code., but VAL field remain 1 and RVAL change according to the PV set value.  is any additional setting required in the IOC / record field / python code?
epics> dbpf  PHASE_SHIFT:CHANNELA 2
DBF_DOUBLE:         2
epics> Channel 48 is set value -  2.0
dbpr  PHASE_SHIFT:CHANNELA 4
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: 1
AMSG:               AOFF: 0             ASG :               ASLO: 0
ASP : PTR (nil)     BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00
DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DOL : CONSTANT      DPVT: PTR 0xaaab18f63890
DRVH: 0             DRVL: 0             DSET: PTR 0xffff8c4a6a90
DTYP: pydev         EGU :               EGUF: 0             EGUL: 0
EOFF: 0             ESLO: 1             EVNT:               FLNK: CONSTANT
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV : NO_ALARM      HYST: 0             INIT: 0
IVOA: Continue normally                 IVOV: 0             LALM: 1
LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW : 0
LSET: PTR 0xaaab18f5b790                LSV : NO_ALARM      MDEL: 0
MLIS: ELL 0 [(nil) .. (nil)]            MLOK: 80 de f5 18 ab aa 00 00
MLST: 1             NAME: PHASE_SHIFT:CHANNELA              NAMSG:
NSEV: NO_ALARM      NSTA: NO_ALARM      OIF : Full          OLDSIMM: NO
OMOD: 0             OMSL: supervisory   ORAW: 2             ORBV: 0
OROC: 0             OUT : INST_IO @device1.setv('channel_A', (VAL))
OVAL: 2             PACT: 0             PBRK: PTR (nil)     PHAS: 0
PINI: NO            PPN : PTR (nil)     PPNR: PTR (nil)     PREC: 0
PRIO: LOW           PROC: 0             PUTF: 0             PVAL: 2
RBV : 0             RDES: PTR 0xaaab18e11da0                ROFF: 0
RPRO: 0             RSET: PTR 0xffff8c353610                RVAL: 2
SCAN: Passive       SDIS: CONSTANT      SDLY: -1            SEVR: NO_ALARM
SIML: CONSTANT      SIMM: NO            SIMPVT: PTR (nil)   SIMS: NO_ALARM
SIOL: CONSTANT      SPVT: PTR (nil)     SSCN: <nil>         STAT: NO_ALARM
TIME: 2024-05-24 11:41:38.967049007     TPRO: 0             TSE : 0
TSEL: CONSTANT      UDF : 0             UDFS: INVALID       UTAG: 0
VAL : 1
epics>
Thanks
Vishnu
Re: PyDevice support VAL field remains 1 Vishnu Patel via Tech-talk
Prev: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
Next: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Zimoch Dirk via Tech-talk
Next: Re: PyDevice support VAL field remains 1 Vishnu Patel via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
