Subject: |
Issue with medm's PV Info Message on Ubuntu 24.04 |
Sang-Woo Kim via Tech-talk <[email protected]> |
To: |
Date: |
Fri, 31 May 2024 16:38:49 +0900 |
Dear Techtalk Community, I am writing to bring to your attention an issue we encountered with the PV Info message in the medm application on Ubuntu 24.04. The use of `sprintf` for overlapping buffer read/write operations has led to undefined behavior. The `sprintf` function was reading from and writing to the same buffer, causing memory overlap issues and unexpected results. We have addressed this problem by replacing `sprintf` with `snprintf`, ensuring safe string concatenation and buffer management. The changes have been tested on Ubuntu 24.04 and have resolved the issue. For more details, you can review the pull request here: https://github.com/epics-extensions/medm/pull/8Best regards, Sang-Woo Kim PLS-II, PAL, South Korea
- Re: Issue with medm's PV Info Message on Ubuntu 24.04 Soliday, Robert T. via Tech-talk
Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
Suspended task in connection with autosave Heinz Junkes via Tech-talk
<2024>
2025
2026
Re: [EXTERNAL] pv.read() after pv.write() returns old value instead of new value using org.phoebus.pv.PV Kasemir, Kay via Tech-talk
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
