Folks,
We would like to start to enable the firewalls on our Linux machines that are running Linux IOCs and clients.
The only “official” documentation I can find is the most recent CA Reference Manual:
https://epics.anl.gov/base/R7-0/8-docs/CAref.html#firewall
And in “How to Configure Channel Access”:
https://epics-controls.org/resources-and-support/documents/howto-documents/configure-channel-access/#Firewalls
Both of these are very terse, and do not explicitly discuss the case of multiple IOCs on a Linux server.
The tech-talk thread I am responding to did not reach a clear conclusion and recommendation.
My configuration is as follows:
- RHEL 9 servers running multiple IOCs
- All clients are either on that server or other machines on the same subnet. Thus, CA searches can simply use broadcasts, and we don’t need to use the
IP Tables mechanism.
Is it sufficient to follow these instructions?
Or do the multiple IOCs require additional complexity?
On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, February 28, 2020 4:26 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: firewalld configuration for EPICS?
On Mon, 24 Feb 2020 at 14:10, Goetz Pfeiffer via Tech-talk <[email protected]> wrote:
Settings for EPICS clients:
firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=tcp accept"
firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=udp accept"
firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=tcp accept"
firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=udp accept"
Additional settings for EPICS servers:
firewall-cmd --add-rich-rule="rule port port=5064 protocol=tcp accept"
firewall-cmd --add-rich-rule="rule port port=5064 protocol=udp accept"
firewall-cmd --add-rich-rule="rule port port=5065 protocol=tcp accept"
firewall-cmd --add-rich-rule="rule port port=5065 protocol=udp accept"
Channel Access does not use TCP on the beacon port (aka CA_REPEATER_PORT, ca-2, 5065). Opening it does no harm, but is not needed.
