1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: RE: firewalld configuration for EPICS?
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Tue, 4 Jun 2024 06:10:16 +0000
Hello Mark
We have similar setup to yours, multiple IOCs on a server and clients on different machines, same and different subnets. For the same subnet we use the UDP broadcast rule mentioned here, you don’t need the whole script, just run the iptables rule in the “up” mode section on startup and you’re good to go. For clients on different subnets, I think you need to have an EPICS gateway, one for each subnet. Another option you can use, as Freddie pointed out, is to have the IOCs listen on the loopback and one EPICS gateway running on port 5064.
Please note that the previous is working when adding the NIC to the trusted zone in Rocky Linux 8, I tried working on configuring the firewall to work with our setup, some IOCs work and others didn’t. But as I am writing this, I think if you add an EPICS gateway to each server listening on port 5064, you could have the firewall working while allowing ports 5064 and 5065 both TCP and UDP.
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Tuesday, June 4, 2024 2:04 AM
To: EPICS Tech Talk <[email protected]>
Folks,
Ø  Is it sufficient to follow these instructions?
Ø  https://epics-controls.org/resources-and-support/documents/howto-documents/configure-channel-access/#Firewalls
Ø  Or do the multiple IOCs require additional complexity?
I have now empirically answered that question, and it is NOT sufficient to implement the firewall rules documented in the CA Reference Manual.  When I do that, I can only connect to the first IOC I start.
Is there a recipe for configuring the firewall when multiple IOCs are running on that Linux machine?  I can access all IOCs from CA clients running on that same machine, but not from clients running on other machines.
Sent: Monday, June 3, 2024 3:26 PM
[email protected]>
Folks,
We would like to start to enable the firewalls on our Linux machines that are running Linux IOCs and clients.
The only “official” documentation I can find is the most recent CA Reference Manual:
https://epics.anl.gov/base/R7-0/8-docs/CAref.html#firewall
And in “How to Configure Channel Access”:
Both of these are very terse, and do not explicitly discuss the case of multiple IOCs on a Linux server.
The tech-talk thread I am responding to did not reach a clear conclusion and recommendation.
My configuration is as follows:
-          RHEL 9 servers running multiple IOCs
-          All clients are either on that server or other machines on the same subnet.  Thus, CA searches can simply use broadcasts, and we don’t need to use the IP Tables mechanism.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, February 28, 2020 4:26 AM
[email protected]>
Subject: Re: firewalld configuration for EPICS?
Small note:
On Mon, 24 Feb 2020 at 14:10, Goetz Pfeiffer via Tech-talk <[email protected]> wrote:
Settings for EPICS clients:
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=udp accept"
Additional settings for EPICS servers:
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=udp accept"
Channel Access does not use TCP on the beacon port (aka CA_REPEATER_PORT, ca-2, 5065). Opening it does no harm, but is not needed.
Cheers,
~Ralph
RE: firewalld configuration for EPICS? Mark Rivers via Tech-talk
Prev: Re: firewalld configuration for EPICS? Gerrit Kühn via Tech-talk
Next: an IOC based on asynPortDriver 周逸媚 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Required Perl modules? John Dobbins via Tech-talk
