Thanks. Very useful. John
Sent: Monday, June 3, 2024 9:31:06 PM To: John Dobbins <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: Required Perl modules? Hi John,
This is what I have found necessary for our installations.
In order to build EPICS base and the synApps support tree, including our local application, on RHEL 9 I needed to install the following additional packages:
areaDetector needs aravis to be installed. aravis requires installing
Measurement Computing support requires installing their uldaq library, which is built from source. That can be built and installed as follows:
./configure make sudo make install Mark
Sent from my iPhone
On Jun 3, 2024, at 7:20 PM, John Dobbins via Tech-talk <[email protected]> wrote:
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
